Accord Coupe Projects or Purchase Suggestions "LINKS"
hughezee
  • Administrators
Welcome to the New Accord Coupe Projects or Purchase Suggestions Topic for 2017, the old topic had been with us since we started out however' had developed several errors, with broken links missing pictures and more recently has had malicious uploads which have presented security risk to the whole site, the person has been identified and banned permanently, so now feel free to contribute to the once popular discussion. ;)
  • Like 6
Link to comment
  • Moderators
Pretty sure this is it Pete :
Check the MOT history of a vehicle
Registration number: S552UEY
  • Vehicle make HONDA
  • Vehicle model ACCORD
  • Date first used 11 September 1998
  • Fuel type Petrol
  • Colour Black
MOT history of this vehicle
  • Test date 24 November 2016
  • Expiry date 21 December 2017
  • Test Result Pass
  • Odometer reading 115,605 miles
  • MOT test number 6577 1280 2013
  • Test date 22 December 2015
  • Expiry date 21 December 2016
  • Test Result Pass
  • Odometer reading 115,358 miles
  • MOT test number 5496 1825 8194
  • Test date 2 December 2015
  • Test Result Fail
  • Odometer reading 115,346 miles
  • MOT test number 8190 3221 5597
  • Reason(s) for failure
    Nearside Front coil spring broken (2.4.C.1a)
    Offside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
  • Test date 27 October 2014
  • Expiry date 26 October 2015
  • Test Result Pass
  • Odometer reading 113,416 miles
  • MOT test number 4889 0090 4356
  • Advisory notice item(s)
    Offside Front Tyre worn close to the legal limit (4.1.E.1)
    Metal brake pipes becoming corroded
  • Test date 18 October 2014
  • Test Result Fail
  • MOT test number 7193 5179 4299
    Exhaust has a major leak of exhaust gases (7.1.2)
    Offside Side repeater insecure (1.4.A.2b)
  • Test date 11 October 2013
  • Expiry date 10 October 2014
  • Test Result Pass
  • Odometer reading 108,959 miles
  • MOT test number 6897 9458 3230
    Brake pad(s) wearing thin (3.5.1g)
    Offside Rear Tyre worn close to the legal limit (4.1.E.1)
    Exhaust has a minor leak of exhaust gases (7.1.2)
  • Test date 28 September 2013
  • Test Result Fail
  • MOT test number 2050 4137 3214
    Drivers seat insecure (6.2.A.1)
    Offside Headlamp aim too high (1.8)
    Battery insecure (1.9.1)
    Nearside Rear Anti-roll bar linkage damaged and seriously weakened (2.4.G.1)
    Nearside Front Tyre not fitted in accordance with side wall instructions (4.1.D.1f)
  • Test date 22 September 2012
  • Expiry date 23 September 2013
  • Test Result Pass
  • Odometer reading 105,388 miles
  • MOT test number 3756 7676 2416
    Front registration plate deteriorated but not likely to be misread (6.3.1d)
    Rear Exhaust has a minor leak of exhaust gases (7.1.2)
  • Test Result Fail
  • Odometer reading 105,387 miles
  • MOT test number 7857 6666 2207
    Offside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
  • Test date 24 September 2011
  • Expiry date 23 September 2012
  • Test Result Pass
  • Odometer reading 101,623 miles
  • MOT test number 5192 2746 1247
    Front Brake pad(s) wearing thin (3.5.1g)
  • Test date 21 September 2010
  • Expiry date 20 September 2011
  • Test Result Pass
  • Odometer reading 97,392 miles
  • MOT test number 9101 7496 0261
  • Test date 17 September 2010
  • Test Result Fail
  • MOT test number 1013 7076 0256
    Offside Rear Brake pad(s) less than 1.5 mm thick (3.5.1g)
    Rear discs badly worn and corroded
  • Test date 11 September 2009
  • Expiry date 10 September 2010
  • Test Result Pass
  • Odometer reading 93,543 miles
  • MOT test number 1133 5485 9281
  • Test date 18 August 2008
  • Expiry date 17 August 2009
  • Test Result Pass
  • Odometer reading 90,489 miles
  • MOT test number 3516 6143 8443
  • Test date 23 August 2007
  • Expiry date 18 September 2008
  • Test Result Pass
  • Odometer reading 87,993 miles
  • MOT test number 3442 7593 7462
    Nearside Rear brake disc slightly scored (3.5.1h)
    Nearside Front brake disc slightly scored (3.5.1h)
  • Test date 16 September 2006
  • Expiry date 18 September 2007
  • Test Result Pass
  • Odometer reading 80,454 miles
  • MOT test number 2734 5975 6291
Yes, it's a 2 litre as well.
Link to comment
  • Moderators
Blimey! Thats had a hard life. .how is it people can drive fine cars with all those faults? And so many cars have tyre advisories ,,,, really not that difficult to check are they ? :(
And the log book missing, very careless attitude methinks...
What else is wrong that is hidden away? :huh:
  • Like 2
Link to comment
  • Moderators
Whoever buys it will need to budget for new front springs and shocks i reckon. It looks like the bare minimum was done each year to gain a pass so when the front spring broke presumably only the one would have been renewed causing severe imbalance across the springs and also the shocks. Only way to get it safe is to bin the springs and shocks now.
Before i got my Coupé, some clever character had replaced one complete front leg (spring,shock, hub, disc, caliper and pads! :o ) to replace a leaky front shock. This meant two imbalanced springs and shocks and worse still, one knackered disc and pair of pads!
Soon after i got it, one of the front shocks went so i replaced both with second hand from a known source and the springs at the same time and that's when i noticed the knackered disc. New discs and pads followed although one side was like new.
Totally transformed the ride and handling! The braking too as not only were the pads and discs new, but the shocks helped improve the braking as well.
  • Like 2
Link to comment
On 24/04/2017 at 10:08 AM, hughezee said:
Looks a cracker Bill, thanks for sharing ;)
Stu . ?? looks fine low miles the damage on the vinyl section of the drivers seat seems the achilles heal on these cars, although mine is not bad there, mine is the vinyl panel that has the seat forward lever that has damage?
Link to comment
  • The topic was pinned
  • Administrators
Link to comment
  • Moderators
On 4/27/2017 at 8:12 AM, hughezee said:
Sold already !
But here is another one but it looks a bit on the expensive side !
http://www.ebay.co.uk/itm/332198911753?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
  • Like 2
Link to comment
  • The title was changed to Accord Coupe Projects or Purchase Suggestions "LINKS"
