Administrators hughezee Posted April 8, 2015 Author Administrators Report Share Posted April 8, 2015 Yes new fluid is clear and the old fluid should be orangey brown colour that’s normal, just empty the reservoir well till it’s almost empty and then refill to max mk. The results should be immediate if not at least by the time you have used the whole bottle Also space out the changes between when the car is driven over the next week or so and report back on how the steering feels Link to comment Share on other sites More sharing options...
blackstreet62 Posted April 9, 2015 Report Share Posted April 9, 2015 Hey Cryistic yes i'm with you... i 'm doing a 100ml a day,haven't felt a difference as yet but will push on with it as i guess this takes time yes? Edwin Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted April 9, 2015 Founding Member Report Share Posted April 9, 2015 Hey Cryistic yes i'm with you... i 'm doing a 100ml a day,haven't felt a difference as yet but will push on with it as i guess this takes time yes? Edwin I used a 500ml syringe, so mine was probably a bit quicker http://www.sealey.co.uk/PLPageBuilder.asp?id=20&method=mViewProduct&productid=15121 2 Link to comment Share on other sites More sharing options...
V6vtec Posted April 24, 2015 Report Share Posted April 24, 2015 Changed my fluid this week as shown by Stu last week and all I can say is cheers Stu for the advice and what to get, took me minutes to change and with no mess too. Cheers buddy. 2 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted April 24, 2015 Founding Member Report Share Posted April 24, 2015 Good stuff. That's what being part of Honda6 is all about, helping each other out. 2 Link to comment Share on other sites More sharing options...
V6vtec Posted April 24, 2015 Report Share Posted April 24, 2015 That's right and I've met some very nice people in person and over the phone or facebook. Very nice community here. 2 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted April 25, 2015 Founding Member Report Share Posted April 25, 2015 Certainly is 2 Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted July 27, 2016 Founding Member Report Share Posted July 27, 2016 I replaced the power steering cooling pipe and lost a little fluid in the process. Still above minimum, but is there any specific fluid I should use to top it up? 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted July 27, 2016 Moderators Report Share Posted July 27, 2016 Hi Paul, check the filler cap, it usually says on there what it needs. On mine it is Dexron II-D and i'm sure on my last Accord coupé it was the same but i've a feeling your generation Accord coupé specifies something different. Stu will probably be along soon with a definite answer but check the PAS fluid filler cap just to see if it does say. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted July 27, 2016 Author Administrators Report Share Posted July 27, 2016 The Honda power steering fluid is a special blend with the pump in mind as the rest of the system is basically the same as any other hydraulic steering system. Also the Honda fluid doesn't mix well with other off the shelf fluids and has a tendency to form foam and this can lead to heavy steering and pump damage So basically your looking for Honda PSF-S fluid Part Number-08284-99902HE or the alternative I've been using with good results is linked below 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted July 27, 2016 Moderators Report Share Posted July 27, 2016 Thought as much Stu! 2 Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted July 28, 2016 Founding Member Report Share Posted July 28, 2016 Thanks guys - I have ordered the Lucas fluid....What I have already is red.... Cheers Paul 2 Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted August 2, 2016 Founding Member Report Share Posted August 2, 2016 Lucas fluid arrived and added - seems to be just fine! Thanks Stu. 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 8, 2017 Moderators Report Share Posted May 8, 2017 If you are looking for power steering fluid, genuine Honda, check this out. £11.99 delivered per litre. http://www.ebay.co.uk/itm/222490293801?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted May 8, 2017 Author Administrators Report Share Posted May 8, 2017 That is a good a price delivered Pete, thanks for sharing mate 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 9, 2017 Moderators Report Share Posted May 9, 2017 Ordered 2 litres from these guys yesterday and when I got in from work tonight there they were ,! Stunning service Straight out to the new Accord to start the change. ... 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted June 14, 2019 Moderators Report Share Posted June 14, 2019 Finally run out of ps fluid and the best price i could find is now 14 quid plus delivery . The Elysion still has a minor leak which i haven't managed to track down yet, suspect is a fitting behind the engine, above the chassis against the bulkhead...just can't get to it as Honda managed to cram a big engine into a small space 😬 Whilst perusing that well known auction shite looking for stuff I don't really need ! , I came across a guy selling two bottles of the stuff...we agreed a price of £11.00 bottle . As I don't think I will use two up in the next year then if anyone wants the spare bottle when it arrives its yours for same cost plus postage of course, no idea what that will be yet but just cost is fine. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 14, 2019 Author Administrators Report Share Posted June 14, 2019 12 hours ago, PTR200S said: The Elysion still has a minor leak which i haven't managed to track down yet, suspect is a fitting behind the engine, above the chassis against the bulkhead... Doesn't sound good in that area could be the top seal on the rack, I have had great success with the Lucas stuff, my power steering fluid is running very clean since using it too. 1 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 18, 2019 Moderators Report Share Posted June 18, 2019 Out of interest Stu, have you ever tried ATF-U/Valvoline or smilar ATF for PAS fluid? I've been using it for quite a while in mine, (both) and it seems to have sorted minor weps and gives light (but nicely weighted), quiet and smooth steering in both. Also worked well in the Jeep that had a steering box - better than Dexron II-D which was the specified fluid. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 18, 2019 Author Administrators Report Share Posted June 18, 2019 I have tried various fluids over the years and year 2000 ish systems seem perfectly fine on ATF, in general, providing its the majority fluid that is... 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted June 19, 2019 Moderators Report Share Posted June 19, 2019 Arrived, sealed containers at £11 quid each 😁 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 19, 2019 Author Administrators Report Share Posted June 19, 2019 Excellent, great price 👍 2 Link to comment Share on other sites More sharing options...
Andy Mc Posted July 5, 2021 Report Share Posted July 5, 2021 Thanks to inspiration on here started with p/s fluid renewal. Was it supposed to be this colour? https://www.dropbox.com/s/c8gmyh1rctajjok/20210705_122837.jpg?dl=0 https://www.dropbox.com/s/lmtd9ozmoemauht/20210705_122849.jpg?dl=0 Stinky stuff either way 🤭 1 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted July 5, 2021 Moderators Report Share Posted July 5, 2021 Shouldn't be that colour! Hopefully the next part-change will be somewhat cleaner! 2 Link to comment Share on other sites More sharing options...
Andy Mc Posted July 5, 2021 Report Share Posted July 5, 2021 Looks like undiluted vimto hah. Probably original or topped up with some cheap stuff at some point. Nice translucent lucas stuff in now 👍 1 1 Link to comment Share on other sites More sharing options...
