Moderators PTR200S Posted April 7, 2020 Moderators Report Share Posted April 7, 2020 Excellent Stu, loads of jobs done ! What are you using in the fuel tank? Carlube injector cleaner? Does the Oddy have the five speed box? DW1? or "Z1" stuff? Wondered if I should be using DW1 in my Elysion, just been using the stuff that I use in the Coupe as I bought loads last year 🙄😝 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 7, 2020 Author Administrators Report Share Posted April 7, 2020 17 minutes ago, PTR200S said: Wondered if I should be using DW1 in my Elysion, just been using the stuff that I use in the Coupe as I bought loads last year 🙄😝 Your Elysion takes ATF-Z1 and much newer motors that spec DW1 shift better on Z1 compatible fluids once they've got a few miles on them. 21 minutes ago, PTR200S said: What are you using in the fuel tank? Carlube injector cleaner? Yup works well too 👍 21 minutes ago, PTR200S said: Does the Oddy have the five speed box? DW1? or "Z1" stuff? it has the 4-speed but shifts fast no complaints 😉 2 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 8, 2020 Author Administrators Report Share Posted April 8, 2020 On 4/7/2020 at 7:37 PM, hughezee said: Valve cover weeping a little, will sort that tomorrow 😉 The last picture clearly showing the leak at the back of the valve cover, so also fitted a lower pressure Honda PCV to hopefully solve it plus a new genuine valve cover seal 👍 Also, I have a new set of rear discs and pads for the odyssey, the old ones are ok, little scoring from some Euro-trash pads I fitted last year, so do you think I should get them done while I have time or chill out? 3 Link to comment Share on other sites More sharing options...
Site Subscriber’s davebrads Posted April 8, 2020 Site Subscriber’s Report Share Posted April 8, 2020 On 4/8/2020 at 1:57 PM, hughezee said: Also, I have a new set of rear discs and pads for the odyssey, the old ones are ok, little scoring from some Euro-trash pads I fitted last year, so do you think I should get them done while I have time or chill out? I don't think my answer would be the same as yours Stu 1 1 1 Link to comment Share on other sites More sharing options...
Founding Member Brett Posted April 8, 2020 Founding Member Report Share Posted April 8, 2020 Do it when we can drive again bud. 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 8, 2020 Author Administrators Report Share Posted April 8, 2020 Thanks for your input chaps 👍 3 Link to comment Share on other sites More sharing options...
Founding Member Retro Rich Posted April 8, 2020 Founding Member Report Share Posted April 8, 2020 Hahahaha, I think you should chill out and take a brake 😂 1 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 8, 2020 Moderators Report Share Posted April 8, 2020 Looks nice and clean in there 👍 what sort of gasket does that use? paper? or a Honda rubber seal type? 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 8, 2020 Moderators Report Share Posted April 8, 2020 On 4/8/2020 at 1:57 PM, hughezee said: Also, I have a new set of rear discs and pads for the odyssey, the old ones are ok, little scoring from some Euro-trash pads I fitted last year do you think I should get them done while I have time or chill out? Get it done, have the nice shiny brakes to use for YOUR benefit not the next owner, keep the other as spares.... This is the equivalent of buying a new car and then putting seat covers on it !!! ......so the next owner can benefit from the new seats but the rest of the car is trashed 😝 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 8, 2020 Author Administrators Report Share Posted April 8, 2020 6 minutes ago, PTR200S said: what sort of gasket does that use? paper? or a Honda rubber seal type? Rubber seal > https://www.ebay.co.uk/itm/Genuine-AJUSA-OEM-Replacement-Valve-Cover-Gasket-Seal-Set-56006000/332783886830? 2 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 8, 2020 Moderators Report Share Posted April 8, 2020 So did the seal show signs of degradation? or just "tired" ? Just wondered if it had been chemically attacked by oil....just discovered they put bioshite in kerosene heating oil, wrecked an "O" ring on a sensor on the intake to the burner in the heating boiler, at home, ...fuel oil everywhere.....🤬 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 8, 2020 Author Administrators Report Share Posted April 8, 2020 Just now, PTR200S said: So did the seal show signs of degradation? or just "tired" ? I replaced it previously with a blueprint one when I did the cambelt it still seems good, seen OEM ones leak after a couple of years, difficult to get them to seal once removed as Honda used a tack agent with the seal, similar to Loctite 3020 Spray Tack, been meaning to buy some actually.😅 2 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 9, 2020 Author Administrators Report Share Posted April 9, 2020 A good clean with spirits and a little waxing on the vulnerable subframe areas, before the wheels went on 😉 3 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 9, 2020 Moderators Report Share Posted April 9, 2020 Great work Stu! I take it you're enjoying an energy boost at the moment as well! 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 11, 2020 Author Administrators Report Share Posted April 11, 2020 On 4/8/2020 at 7:17 PM, PTR200S said: Get it done, have the nice shiny brakes to use for YOUR benefit not the next owner, keep the other as spares... 4 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 15, 2020 Author Administrators Report Share Posted April 15, 2020 Today I decided to reseal the valve cover again 🙃 this time with 3020 and even put some 222 on the caliper carrier bolts, which I missed out of the recent video 😁 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 17, 2020 Author Administrators Report Share Posted April 17, 2020 Rear parking brake needed some fine-tuning other than that, it's driving sweet as a nut 😁 2 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 21, 2020 Author Administrators Report Share Posted April 21, 2020 The odyssey is now one seriously sorted motor, it has been such a pleasure to work on, I couldn't resist ordering a few more bits from the good people @ amayama.com should arrive 2-6 weeks due to delays. 😉 1 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 22, 2020 Moderators Report Share Posted April 22, 2020 Isn't in great when everything comes together nicely ! I presume you are keeping it then !!!!!🙂 You have done loads of stuff on it now what more could you need from amayama ....is it a secret modification????!!! ejector seat? , Rear oil slick dispenser?, Secret compartment for the toilet roll stock??!!! 🙂 2 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 22, 2020 Author Administrators Report Share Posted April 22, 2020 21 minutes ago, PTR200S said: I presume you are keeping it then !!!!!🙂 Yeah, nothing comes close to it even the KIA's, Toyota's I looked at a while ago are crap, by comparison, it drives like a new car too. 23 minutes ago, PTR200S said: You have done loads of stuff on it now what more could you need from amayama I ordered a few suspension boots and genuine new tie rods ends (couldn't find anything compatible in a decent aftermarket brand). 26 minutes ago, PTR200S said: Rear oil slick dispenser? I can borrow my mates R8 that's always chucking oil out somewhere, although I refuse to work on it now its waste of my time. 🤣 Just some bigger boots (still on coupe size tryes atm) and towbar to follow at some point 👍 2 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 22, 2020 Moderators Report Share Posted April 22, 2020 4 hours ago, PTR200S said: is it a secret modification????!!! Anti-tailgater device? Fill it with water and bright red food dye! 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted May 11, 2020 Author Administrators Report Share Posted May 11, 2020 Towbar ordered from Watling Engineers, cheers Pete 👍 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 11, 2020 Moderators Report Share Posted May 11, 2020 Excellent, they are really helpful I found, able to answer the queries regarding the blind chassis mounts on the Elysion. Did you get the electric kit from them too? or Towsure? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted May 11, 2020 Author Administrators Report Share Posted May 11, 2020 4 minutes ago, PTR200S said: Did you get the electric kit from them too? Got the whole kit £231.60 inc. VAT, Bargain IMO 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 11, 2020 Moderators Report Share Posted May 11, 2020 19 minutes ago, hughezee said: Got the whole kit £231.60 inc. VAT, Bargain IMO Sure that was same cost as mine for Elly, delivered... Wonder if the chassis at the rear of the Oddy is same as Elly, or pretty much....what was the item code for your bar ? Be interesting to see if you require any instruction translation from "engineer speak" to English !!!! 1 Link to comment Share on other sites More sharing options...
