Moderators PTR200S Posted March 23, 2019 Moderators Report Share Posted March 23, 2019 Although Mikes Coupe not ready I see Mke actually did make it !!! 😃 4 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 3, 2019 Author Administrators Report Share Posted June 3, 2019 Loads of progress on the Odyessy so thought I would share a few shots, more to follow soon 😉 Fuel gauge niggle finally sorted 😁 4 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted June 4, 2019 Moderators Report Share Posted June 4, 2019 Few new bits then ! Was it old age deterioration or an actual mech failure ? 3 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 4, 2019 Moderators Report Share Posted June 4, 2019 Looks to be a right excavation mission to get the sender unit! What were the fuel gauge niggles you had Stu? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 4, 2019 Author Administrators Report Share Posted June 4, 2019 4 hours ago, PTR200S said: Was it old age deterioration or an actual mech failure ? Apart from the fuel gauge niggle nothing else is wrong TBH 😊 1 hour ago, Laird_Scooby said: What were the fuel gauge niggles you had Stu? little inaccuracies between ignition cycles, it works fine now 👍 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 4, 2019 Author Administrators Report Share Posted June 4, 2019 Jet washed out the arches vigorously and plenty of degreaser too, zero rust in any of the normally prone areas, but I intend to keep it that way.👍 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 7, 2019 Author Administrators Report Share Posted June 7, 2019 Still waiting on a few minor and major parts for the odyssey but still plenty of things to do though. 🤔 2 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 7, 2019 Moderators Report Share Posted June 7, 2019 Good to see you keeping busy Stu! 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 8, 2019 Author Administrators Report Share Posted June 8, 2019 More bits to fit from fleabay, but have other jobs to do atm 😑 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 10, 2019 Author Administrators Report Share Posted June 10, 2019 Few more parts arrived for the odyssey including new Japanese made bump stops (no longer available from Honda) shocks all assembled and the old bump stops were almost an inch shorter with wear and then the heavens opened up. 😞 Those with a keen eye might spot my newly installed rear camera, with all the cabling neatly hidden away in the tailgate following the existing wiring loom. 👍 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 10, 2019 Moderators Report Share Posted June 10, 2019 40 minutes ago, hughezee said: Those with a keen eye might spot my newly installed rear camera, Be interesting to see if being mounted on the tailgate causes any problems long-term with the camera Stu. - i still haven't fitted my rear camera on the Sterling, original thought was on the number plate plinth but shutting the boot can sometimes be a bit of a thud so been looking at other places where that won't be a problem. Likewise on the Volvo although there is some trim at the back of the headlining that i could use to mount the rear cam on. More thought required for me i reckon! What are all the toys in those boxes then? Or is it a secret until you fit/install/otherwise get them out to play with? 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 10, 2019 Author Administrators Report Share Posted June 10, 2019 3 minutes ago, Laird_Scooby said: Be interesting to see if being mounted on the tailgate causes any problems long-term with the camera Stu it's a rear camera that pairs up with my front dash camera and its got a strong magnet that holds it on the base and it doesn't move easily and it is virtually impossible to slam the boot on the Odyssey, I did test it as I did have my suspicions it would move but it doesn't 👍 10 minutes ago, Laird_Scooby said: What are all the toys in those boxes then? Or is it a secret until you fit/install/otherwise get them out to play with? No secret buddy there's a BOSE sub from an accord is in the nearest box (pictured further up) and some new rear wheel bearings in the box further back... 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 16, 2019 Author Administrators Report Share Posted June 16, 2019 The rear of the car almost done, few pictures 😉 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 16, 2019 Moderators Report Share Posted June 16, 2019 Great work there Stu! 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 16, 2019 Author Administrators Report Share Posted June 16, 2019 1 hour ago, Laird_Scooby said: Great work there Stu! Thanks, buddy, I replaced all mechanical bits in pairs including rear calipers (will be doing front ones soon) and filled all inner rear arches with wax and it started dripping out of a few odd places, obviously where the seam sealer had failed with age, so all good. 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 16, 2019 Moderators Report Share Posted June 16, 2019 Does the wax have a rust killer built in as well Stu or is it purely protective? Always best doing pairs of things, bet things have sharpened up all round now? 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 16, 2019 Author Administrators Report Share Posted June 16, 2019 6 minutes ago, Laird_Scooby said: Does the wax have a rust killer built in as well Stu or is it purely protective? Wax injected fluid for protecting underbody, chassis box sections, door panels, sills, etc. Fluid nature allows rust to be eliminated or prevented in hard to reach spaces. As quoted from the manufacture buddy, used it for a few years now and never had to re-apply it although I still do, keeps the rust under control... 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 16, 2019 Moderators Report Share Posted June 16, 2019 Sounds a useful drop of goo - which one is it? 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 17, 2019 Author Administrators Report Share Posted June 17, 2019 12 hours ago, Laird_Scooby said: Sounds a useful drop of goo - which one is it? Just done the final coat of wax over the painted areas as pictured above and another three cans ordered to finish the rest of the car fill sills etc. 2 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 17, 2019 Moderators Report Share Posted June 17, 2019 Thanks for that Stu - think i might invest in some of that soon! 1 Link to comment Share on other sites More sharing options...
Founding Member Brett Posted June 17, 2019 Founding Member Report Share Posted June 17, 2019 10 hours ago, hughezee said: Just done the final coat of wax over the painted areas as pictured above and another three cans ordered to finish the rest of the car fill sills etc. Iv been using this as recommended by Stu love it 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 17, 2019 Moderators Report Share Posted June 17, 2019 Don't know if either of your pair know of a better price but this seems reasonable on fleabay : https://www.ebay.co.uk/itm/Comma-Wax-Seal-Anti-Rust-Treatment-And-Underbody-Protection-WS500M-500ml-Aerosol/292685801218 They also do other multiple listings, best value seems to be this one : https://www.ebay.co.uk/itm/Comma-Wax-Seal-500ml-Aerosol-Anti-Rust-Treatment-Underbody-Protection-WS500M-X5/372344240795 Just under £6 a can with free postage. 2 Link to comment Share on other sites More sharing options...
Founding Member Brett Posted June 17, 2019 Founding Member Report Share Posted June 17, 2019 When Stu fitted my LED headlights he sprayed the front of car behind bumper for good measure 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 17, 2019 Author Administrators Report Share Posted June 17, 2019 1 hour ago, Laird_Scooby said: Just under £6 a can with free postage Great price Dave 👍 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 17, 2019 Author Administrators Report Share Posted June 17, 2019 1 hour ago, Brett said: he sprayed the front of car behind bumper for good measure Prevention is always better, my coupe still looks brand new in those hard to see areas where rust can lurk and intend to keep it that way too 👍 1 Link to comment Share on other sites More sharing options...
