Administrators hughezee Posted December 10, 2015 Administrators Report Share Posted December 10, 2015 3 34253SV1A01 BULB (T-10) (12V 7W) £4.34 5 34261S84A00 BULB (T10 3CP) (12V 5W) £4.23 6 34401S84A01 BULB (T10 4CP) (12V 6.2W) £8.57 3 35505S84B02 BULB, NEO WEDGE (T3) (BORG INDAK) (14V 50MA) £6.80 3 35505S84N01 BULB, NEO WEDGE (T3) (NS) (14V 50MA) £6.80 7 35850ST7Z01 BULB COMP. (14V 60MA) £5.87 8 35851SZ3A01 BULB COMP. (14V 40MA) £7.73 9 35851SZ5A11 BULB COMP. (14V 40MA) £5.24 10 35852ST3G01 BULB COMP. (14V 60MA) £4.39 11 35861S84A01 BULB, NEO WEDGE (T3) (14V 40MA) (ALPS) £4.45 12 35861S84T01 BULB, NEO WEDGE (T3) (14V 60MA) (TOYO) £4.72 13 35881S84T01 BULB (14V 60MA) £5.87 19 35861S84T01 BULB, NEO WEDGE (T3) (14V 60MA) (TOYO) 1 35505SA5003 SOCKET ASSY., BULB (14V 1.4W) (NS) (BASE:BLACK) £6.58 2 35505SJ4003 SOCKET ASSY., BULB (14V 3W) £5.96 3 35506SA5003 BULB (14V 1.4W) £3.00 4 37102SA5003 SOCKET ASSY., BULB (14V 3.4W) (NS) (BASE:BLACK) £6.73 5 37102S84003 SOCKET ASSY., BULB (BASE:BLUE) (14V 2W) £6.80 7 37237SA5003 BULB (14V 3.4W) (NS) £1.43 8 78105S84003 SOCKET ASSY., BULB £13.03 5 79671S84A41 BULB, NEO WEDGE (14V 100MA) £5.44 6 79672S84A41 BULB, NEO WEDGE (14V 100MA) £5.44 7 79673S84A42 BULB, NEO WEDGE (8V 95MA) £5.44 1 35505S30003 BULB (T5) (14V 1.4W) £2.27 Any questions feel free to ask and if several bulbs appear blown for example in the instrument cluster, I would also consider possibility the light control multiplexer may have a problem. Check out the link below A car’s alternator is not designed to fully restore a depleted battery, but rather to maintain a healthy one. It is important to routinely charge car batteries that are used sporadically – like in a car driven only for short distances. However, whether your car sits outside or is in use every day, you can use a battery charger to keep it starting easily. Most chargers are designed to diagnose, recover, charge and maintain a wide range of batteries, in a wide range of applications. Some trickle chargers can be left on a battery indefinitely. These would be used on a vehicle that is not used all the time or is stored away for the winter or the summer. - See more at: http://blog.batteriesplus.com/2013/the-importance-of-car-battery-chargers#sthash.5wLrIQcb.dpuf A car’s alternator is not designed to fully restore a depleted battery, but rather to maintain a healthy one. It is important to routinely charge car batteries that are used sporadically – like in a car driven only for short distances. However, whether your car sits outside or is in use every day, you can use a battery charger to keep it starting easily. Most chargers are designed to diagnose, recover, charge and maintain a wide range of batteries, in a wide range of applications. Some trickle chargers can be left on a battery indefinitely. These would be used on a vehicle that is not used all the time or is stored away for the winter or the summer. - See more at: http://blog.batteriesplus.com/2013/the-importance-of-car-battery-chargers#sthash.5wLrIQcb.dpuf A car’s alternator is not designed to fully restore a depleted battery, but rather to maintain a healthy one. It is important to routinely charge car batteries that are used sporadically – like in a car driven only for short distances. However, whether your car sits outside or is in use every day, you can use a battery charger to keep it starting easily. Most chargers are designed to diagnose, recover, charge and maintain a wide range of batteries, in a wide range of applications. Some trickle chargers can be left on a battery indefinitely. These would be used on a vehicle that is not used all the time or is stored away for the winter or the summer. - See more at: http://blog.batteriesplus.com/2013/the-importance-of-car-battery-chargers#sthash.5wLrIQcb.dpuf Link to comment Share on other sites More sharing options...
welland99 Posted December 10, 2015 Report Share Posted December 10, 2015 Thanks a lot - it's exactly what i was looking for. Just out of interest, are those prices current? 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 10, 2015 Author Administrators Report Share Posted December 10, 2015 Yes the prices should be current but some dealers will be cheaper or will be 10% more depending on their parts turnover with Honda UK Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted December 10, 2015 Moderators Report Share Posted December 10, 2015 OUCH!!! Those prices!!!!! Link to comment Share on other sites More sharing options...
welland99 Posted December 10, 2015 Report Share Posted December 10, 2015 OUCH!!! Those prices!!!!! unreal! Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted December 11, 2015 Founding Member Report Share Posted December 11, 2015 You get what you pay for I think and yes, although the prices of Honda bulbs are eye watering, I would much rather buy a genuine Honda bulb for £5 and know it will probably outlast the car than buy El Cheapo bulbs and have to change the blooming things every week. I'd just get the Honda bulbs personally. 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted December 11, 2015 Moderators Report Share Posted December 11, 2015 Me being me i just upgrade to LEDs anyway Much cheaper and should outlast me, never mind the car! 2 Link to comment Share on other sites More sharing options...
Mangoman Posted March 22, 2017 Report Share Posted March 22, 2017 Hi chaps. Strangely enough I have only just noticed that some of my Dash Lights are not lighting. In the following photo there seems to be the following: Temp Setting on right hand side; Temp Setting Adjuster. (Looks dimmer in real life). A/C On-Off Switch. In the following photo you can only see the Cigar Lighter and the 2 Heated Seat Switches. The Headlight Adjuster and Headlight Washer are not lit. (Sorry camera would not focus). Could someone please tell me what Bulbs I require for each as I cannot work out from Diagrams what I need to get please. Thanks. Also I would like the Standard Bulbs please. Cheers, Bill. Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 22, 2017 Author Administrators Report Share Posted March 22, 2017 Think it was Paul S asking for more info on this I shall get on as soon as I can and would you be fitting LED's if suitable 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 22, 2017 Author Administrators Report Share Posted March 22, 2017 In the meantime might be worth looking at the start of the topic Bill 2 Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted March 22, 2017 Founding Member Report Share Posted March 22, 2017 Yes it was me asking. Still needs doing and is on my list of things to do when it finally warms up outside - and when I find out how to do it... 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 23, 2017 Moderators Report Share Posted March 23, 2017 Hmm, funny that, were they working at one point? Have they failed together? I noticed last night the clock in mine was dark but couldn't recall if it was lit when I got the car,,, just wondering if mine about to start popping. 1 Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted March 23, 2017 Founding Member Report Share Posted March 23, 2017 I had similar issue a couple weeks ago and noticed 2 of my gauge bulbs weren't working and then after switching the engine on and off they were working again. Bill I'm pretty sure the head light adjuster isn't lit. I've got a spare centre control unit at Home and will check tonight about the bulbs but have a feeling you'll know from the other members before I can check. 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 23, 2017 Moderators Report Share Posted March 23, 2017 Looks like i need lamp 3, just got to work out if its easy to get to, have seen a thread somewhere, i think. 1 Link to comment Share on other sites More sharing options...
Mangoman Posted March 23, 2017 Report Share Posted March 23, 2017 14 hours ago, hughezee said: Think it was Paul S asking for more info on this I shall get on as soon as I can and would you be fitting LED's if suitable Hi Stu. I would be really wanting the Original Fitment so as to match up please? Thanks, Bill. Link to comment Share on other sites More sharing options...
Mangoman Posted March 23, 2017 Report Share Posted March 23, 2017 Hi Stu. Yes, it was this Diagram Below that confuses me. Which Bulb is the A/C on-off Switch Light, and which is the Bulb for the Heat Control? (I was thinking 6 & 6?). 5 79671S84A41 BULB, NEO WEDGE (14V 100MA) £5.44 6 79672S84A41 BULB, NEO WEDGE (14V 100MA) £5.44 7 79673S84A42 BULB, NEO WEDGE (8V 95MA) £5.44 Thanks. Bill. Link to comment Share on other sites More sharing options...
Mangoman Posted March 23, 2017 Report Share Posted March 23, 2017 5 hours ago, PTR200S said: Hmm, funny that, were they working at one point? Have they failed together? I noticed last night the clock in mine was dark but couldn't recall if it was lit when I got the car,,, just wondering if mine about to start popping. Yes Pete, I only noticed the Bulbs out for the first time last night....??? But then again I have never really looked at the A/C Control Button at night before so not sure. But the Heat Control switch is definitely new. I think...?? I've always known that the Headlight Washer Switch and the Height Control didn't have, but apparently the Height Control doesn't have a bulb anyway. Strange when you think that is the one Switch you would need to see at night!!! "It's a mystery"......??? And I have just realised that the Hazard Switch is not lit...??? Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 23, 2017 Author Administrators Report Share Posted March 23, 2017 How about I just sort you a replacement unit with new bulbs + the door card lens I promised you I get good discounts from Honda and the foam showing behind the readout screen is probably annoying you as it would me. Then I could just illustrate the process for the benefit of others and you send me your old unit along with your old instrument cluster with the high mileage on it (which replaced the original faulty unit)? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 23, 2017 Author Administrators Report Share Posted March 23, 2017 6 minutes ago, Mangoman said: Headlight Washer Switch Some do have a bulb and the front fog light switch does if you have them fitted that is 2 Link to comment Share on other sites More sharing options...
Mangoman Posted March 23, 2017 Report Share Posted March 23, 2017 Hi Stu. Sounds good to me! Ah, foam hey, I thought it was the LCD leaking.... Shows what I know huh... Is the Hazard Switch supposed to be lit? Link to comment Share on other sites More sharing options...
Mangoman Posted March 23, 2017 Report Share Posted March 23, 2017 3 minutes ago, hughezee said: Some do have a bulb and the front fog light switch does if you have them fitted that is Headlight Washer, does it just pop out? No Fogs on mine. Only Rear... Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 23, 2017 Author Administrators Report Share Posted March 23, 2017 6 minutes ago, Mangoman said: Headlight Washer, does it just pop out? No Fogs on mine. Only Rear... I will dig one out and illustrate it so you're fully prepared when you have all the bits I'm going to send 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 23, 2017 Author Administrators Report Share Posted March 23, 2017 29 minutes ago, hughezee said: I will dig one out and illustrate it so you're fully prepared when you have all the bits I'm going to send The rear of the headlight washer and fog light option buttons, the bulb holders are made of rubber and lift off, rather than twisting out Close up to rear of the centre climate control unit and bulb illumination locations shown below Hope that helps somebody until I can get a video done... 1 Link to comment Share on other sites More sharing options...
Mangoman Posted March 23, 2017 Report Share Posted March 23, 2017 Excellent - thank you....... Headlight Washer Bulb: 35881S84T01 BULB (14V 60MA) Hazard Bulb: 35861S84T01 BULB, NEO WEDGE (T3) (14V 60MA) (TOYO) Confirm? Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 23, 2017 Author Administrators Report Share Posted March 23, 2017 1 hour ago, Mangoman said: Excellent - thank you....... Headlight Washer Bulb: 35881S84T01 BULB (14V 60MA) Hazard Bulb: 35861S84T01 BULB, NEO WEDGE (T3) (14V 60MA) (TOYO) Confirm? No problem and yes those are the ones and I can include them as well 1 Link to comment Share on other sites More sharing options...
