jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 I know the front do most of the work I'm not stupid buddy but the rears are always working as well as it's about a 70/ 30 split on these cars but I know that they are working efficiently and effectively as I have noticed the wear of the pad is about right compared to the fronts and yeah I've been checking as I'm paranoid about sticking calipers again I'm not some rookie I just drive fast and brake hard like I said and it's pretty much every time I drive you should see how quickly my track mg used to kill a set of pads Link to comment Share on other sites More sharing options...
welland99 Posted February 9 Report Share Posted February 9 Today my brake lamp warning light illuminated on my dash, and at the same time the HAND brake light also illuminated. I guess I have blown a bulb, but didn't have anyone with me to help me check, so I'll check tomorrow. Anyway, I noticed that the warning lights illuminated while I was not pressing the brake pedal, so I wondered how the warning lamp is triggered. Does anybody know? 1 Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted February 9 Founding Member Report Share Posted February 9 Might not be related, but it would be worth checking the brake fluid level , just in case it means low fluid.... Rotted pipes could leak fluid... 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 10 Moderators Report Share Posted February 10 Had this before with both lights on, low brake fluid level caused by, as Paul says, a rotted brake pipe, in my case above the fuel tank on the offside rear. I lost the brakes completely....then noticed the lights had come on 🙄🙄🙄🙄 Link to comment Share on other sites More sharing options...
