Lumpy Posted December 16, 2018 Report Share Posted December 16, 2018 Playing up again. Heaving rain for 2 days but maybe coincidental. All brake ligjts ok still. More investigation needed. Never got to conformal coat board 1 3 Link to comment Share on other sites More sharing options...
Lumpy Posted December 16, 2018 Report Share Posted December 16, 2018 Moist again. Makes sense. When dry will remove the tail cluster and check the seal. Maybe make a cover and conformal oat it. Bootlid light collects water so need to look at those too. Fun fun fun 3 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted December 16, 2018 Moderators Report Share Posted December 16, 2018 1 hour ago, Lumpy said: Moist again. Makes sense. When dry will Hairdryer? Link to comment Share on other sites More sharing options...
Lumpy Posted December 16, 2018 Report Share Posted December 16, 2018 20 minutes ago, Laird_Scooby said: Hairdryer? No, it's the 3 litre v6 ☺️ Top of radiator. I will make a shroud up to cover it once done and then remove and clean the seals on the cluster. Today and yesterday has been biblical rain. Love the car on the whole. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 16, 2018 Administrators Report Share Posted December 16, 2018 This topic might be of interest if water ingress is persistent? 2 Link to comment Share on other sites More sharing options...
Lumpy Posted December 17, 2018 Report Share Posted December 17, 2018 1 hour ago, hughezee said: This topic might be of interest if water ingress is persistent? Insightful. Thanks again. Opening the boot sees a fair bit from the left unused foglamp area but will now check the sealer and if it's damp on the underside. I noticed a small split in the boot seal too. We shall overcome. 3 Link to comment Share on other sites More sharing options...
Lumpy Posted December 17, 2018 Report Share Posted December 17, 2018 I will protect this box :-) And lacquer the board, and look for where any moisture is getting in on that side 😃 3 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted December 17, 2018 Moderators Report Share Posted December 17, 2018 Excellent idea! 👍 1 Link to comment Share on other sites More sharing options...
Lumpy Posted December 19, 2018 Report Share Posted December 19, 2018 well, there is hardly a trace of water on the inside of the wing despite the rain but will check again, the water you can see came from the rain and what ran out of the fog light on the left, now that I have to do something about. Still, lets see if this keeps any moisture out of the white box I can make it a bit shallower but it should do the job, so once again, and I only ran the engine for 30 seconds, no warnings up. 4 Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 So in response to this it was a seized caliper the causing my issue Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 15, 2019 Administrators Report Share Posted June 15, 2019 On 3/8/2016 at 9:45 PM, jayhoath83 said: but they work fine cheers for the advice guys Thanks for the followup obviously they weren't working fine after all 😄 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 15, 2019 Moderators Report Share Posted June 15, 2019 I'm thinking maybe the fluid level had dropped bringing the light on or is that a separate warning light on that gen Stu? Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 Yeah that's the thing I couldn't tell as it was seized open not on to the disc so it wasn't getting hot and as I'm on my own I couldn't hold the brakes on and turn the rear wheels to check but when I decided to take it all apart I found out the pot was seized in the caliper. The light issue was sorted after some refurbed calipers and new discs pads and fluid 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 15, 2019 Moderators Report Share Posted June 15, 2019 Probably not enough handbrake travel to turn the light on when the handbrake was up or the fluid level was too low to put the light out. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 15, 2019 Administrators Report Share Posted June 15, 2019 4 minutes ago, Laird_Scooby said: I'm thinking maybe the fluid level had dropped bringing the light on or is that a separate warning light on that gen Stu? Both systems will illuminate the same light, edited my post as some are switched at the handbrake and some earthed so could have been either buddy... 1 Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 10 minutes ago, hughezee said: Both systems will illuminate the same light, edited my post as some are switched at the handbrake and some earthed so could have been either buddy... I think when I had to readjust the hand brake cable it might have cured it as it was only pulling 1 caliper really lol 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 15, 2019 Moderators Report Share Posted June 15, 2019 You probably only had 1 or 2 clicks on the handbrake as well 1 Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 Yeah was 3 n I had to slackened it all off to get the new pads on the new discs 2 Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 Thing is I never use the hand brake as I never park it on a slope 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 15, 2019 Administrators Report Share Posted June 15, 2019 7 minutes ago, jayhoath83 said: Thing is I never use the hand brake as I never park it on a slope You should really to stop things seizing up, but hey each to there own 😊 1 Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 I just service them yearly and it's all good one pot was only seized as the previous owner damaged the piston seal and it let water in they were like it when I bought the car 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 15, 2019 Moderators Report Share Posted June 15, 2019 2 minutes ago, hughezee said: You should really to stop things seizing up, Agreed and i do occasionally, just to make sure they both work (both cars) but at the same time, both cars have a fearsome reputation for giving trouble when the handbrake is used regularly. I like to think i've got the balance right as they both keep working and neither have caused any problems yet. I say yet because a certain RWD car needs a replacement rear axle (diff is noisy and vibrates) so will have to have the shoes etc off my axle to transfer onto the donor axle. The discs are scored so i'll probably renew those and maybe the shoes too, pads, maybe as they were new not long back but i should really renew them with the new discs. Going up to a 3.54:1 diff with the replacement axle (from a 3.91:1) so maybe i can improve on the 38mpg on a run! 2 Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 And it not like the rear calipers don't get a work out as I drive the car quite hard and they get used 1 Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 Who keeps posting confused emojis it's not hard to understand that I rag my car but service it and fix it when it needs it what's the point in having somthing fun and driving it like an old lady I drive all my cars like I've stole them I live on some great country driving roads and my brakes get a heavy work out lol Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 15, 2019 Moderators Report Share Posted June 15, 2019 4 minutes ago, jayhoath83 said: it not like the rear calipers don't get a work out as I drive the car quite hard and they get used Fit new pads all round, same compound and then check the wear on them all in 6 months time - tell me if you still agree with your own statement then. I don't agree with it now and i suspect you wouldn't if you thought about it. When you hit the brakes hard, where does all of the weight of the car go? Onto the front wheels. What would happen to the back wheels if they were being braked as hard as the front ones? They'd lock, that's what. As for posting confused emojis, it's me. You've just read the reason. Nowt wrong with giving your car the beans but at least please understand what you're doing when you hit the brakes, it might save your life at some point! 1 Link to comment Share on other sites More sharing options...
