Site Subscriber’s Chrismas Posted May 27, 2020 Site Subscriber’s Report Share Posted May 27, 2020 Going to fit reverse sensors to the Accord, but could see dirt and rust underneath. The crash bar is a bit rusty and will need cleaning. Doesn't look like the bumper has been off in a while. I reckon most of this will clean up. Plastic clip on the bumper needs sorting, and I'm not sure whether to touch the number plate light mounts which are a bit crusty too. 4 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted May 27, 2020 Administrators Report Share Posted May 27, 2020 That's not too bad, all lower grade soft steel parts and should clean up easily, I would recommend drilling out the spot welds breaking off the upper bumper stiffener support. Properly clean the area de-rust the bracket and repaint and secure with rivets. Also I replaced my rear crash bar as it was pretty bad on the insides, so I just got a new one. 4 Link to comment Share on other sites More sharing options...
Site Subscriber’s Chrismas Posted May 27, 2020 Author Site Subscriber’s Report Share Posted May 27, 2020 Where could I get a new crash bar from? 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted May 27, 2020 Administrators Report Share Posted May 27, 2020 9 minutes ago, Chrismas said: Where could I get a new crash bar from? I ordered mine direct from Honda p/n: 71530-S82-G00ZZ not sure if they're still available now? 4 Link to comment Share on other sites More sharing options...
Site Subscriber’s Chrismas Posted May 29, 2020 Author Site Subscriber’s Report Share Posted May 29, 2020 On 5/28/2020 at 12:12 AM, hughezee said: 71530-S82-G00ZZ The bar cleaned up after removing it, and a coat of silver Smoothrite. Didn't fancy drilling the top support, so that got a thorough coating too, after a rub down. The whole area is vulnerable to the elements, due to the number plate lights being open. Bad design in my opinion. When I took the bumper off, I must have knocked the pointy end of the taillight off. Luckily I found it 6ft away on the road, and glued it back. 5 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted May 29, 2020 Administrators Report Share Posted May 29, 2020 Looks great rep points on there way shortly, shame about the light though, I have spares if you decide to replace it? 6 hours ago, Chrismas said: Bad design in my opinion. The bumper would increase wind resistance without a hole, rather have ventilation in that area, a lot of cars suffer heavy corrosion in those places. 3 Link to comment Share on other sites More sharing options...
Site Subscriber’s Chrismas Posted May 30, 2020 Author Site Subscriber’s Report Share Posted May 30, 2020 Fabricated some frames to replace the crusty number plate light mounts, taking inspiration from another post on this site. Doesn't look too bad, and you can't see it anyway. 5 Link to comment Share on other sites More sharing options...
KingK0ng Posted May 30, 2020 Report Share Posted May 30, 2020 Good job mate look clean. 4 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted May 30, 2020 Founding Member Report Share Posted May 30, 2020 Great job. 👍 4 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted May 31, 2020 Moderators Report Share Posted May 31, 2020 Great work there! Bit of a "labour of love" as you can't see most of the results but at least you know it's been done! 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 31, 2020 Moderators Report Share Posted May 31, 2020 Excellent stuff, looks great 👍 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted May 31, 2020 Administrators Report Share Posted May 31, 2020 Great job 👍 3 Link to comment Share on other sites More sharing options...
Founding Member Brett Posted May 31, 2020 Founding Member Report Share Posted May 31, 2020 Great stuff buddy This is the kind of Stuff Stu does 😃 5 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 1, 2020 Administrators Report Share Posted June 1, 2020 15 hours ago, Brett said: Great stuff buddy This is the kind of Stuff Stu does 😃 Nice to see members actively preserving their own motors though 👍 2 1 Link to comment Share on other sites More sharing options...
Site Subscriber’s Chrismas Posted June 2, 2020 Author Site Subscriber’s Report Share Posted June 2, 2020 Next job on mine is to address a liitle bulge in the wheel arch inner edge. One side is OK, but the nearside is warped with a little obvious rust. I'm going to get the Dremel out and grind it out, taking care not to damage the outside edge and wing. Then rust proof it, fill it, and spray it in the proper silver paint I have. 4 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 2, 2020 Administrators Report Share Posted June 2, 2020 Great to see you keeping on top of things 👍 4 Link to comment Share on other sites More sharing options...
welland99 Posted June 3, 2020 Report Share Posted June 3, 2020 On 6/2/2020 at 9:30 PM, Chrismas said: Next job on mine is to address a liitle bulge in the wheel arch inner edge. One side is OK, but the nearside is warped with a little obvious rust. I'm going to get the Dremel out and grind it out, taking care not to damage the outside edge and wing. Then rust proof it, fill it, and spray it in the proper silver paint I have. My rear wheel arches have a wavy shape along their inner edges, like yours. I've always wondered what caused them, but suspected that a very minor impact in a car park might have been related (caused by another car). Or, is it a feature (ahem) of our coupes? 1 1 Link to comment Share on other sites More sharing options...
