Randell Posted February 3, 2019 Report Share Posted February 3, 2019 That's great info, thank you very much for your help. Job for next weekend by the look of it. 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted February 3, 2019 Moderators Report Share Posted February 3, 2019 3 hours ago, Randell said: I believe that the same pump is used for the windscreen washers, If it was, there would be no need for the relay! The relay is there to switch the high current, high pressure headlamp power wash pump which hopefully gives you another clue - it could be a blown fuse for the headlamp power wash, usually about 30-40A so check that first. It could be a previous owner ran it dry and it pulled too much cuirrent, blew the fuse and they just didn't know. Make sure the washer bottle has plenty of fluid in and then check/renew the fuse for the headlamp wash. Try it. You may hear the pump whirr briefly then stop and the fuse is blown. Try another new fuse - got to a maximum of 3 new fuses, you may be able to free it up if it has siezed or is sticky from lack of use. if not, you'll have to strip the bumper off, remove the pump and try to free it off or renew the pump as Pete suggested. 3 Link to comment Share on other sites More sharing options...
Randell Posted February 3, 2019 Report Share Posted February 3, 2019 As soon as daybreaks I'll be out checking my fuses. Thanks everyone. 4 Link to comment Share on other sites More sharing options...
Randell Posted February 6, 2019 Report Share Posted February 6, 2019 The fuses were fine, so I ordered a new pump from Fleabay and it arrived this afternoon. Bumper off this weekend and fit new pump. 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 6, 2019 Moderators Report Share Posted February 6, 2019 Did you check to see if you were getting a feed at the pump ? 3 Link to comment Share on other sites More sharing options...
Randell Posted February 6, 2019 Report Share Posted February 6, 2019 Not yet, I haven't had time to take the bumper or inner wheel arch out. But I can't hear it running. Although I may have ordered the wrong pump, as my car is a 1999 and as far as I can see there is no mount for the second pump. This is the tank fitted to mine.https://www.ebay.co.uk/itm/1998-2002-HONDA-ACCORD-3-0L-V6-WINDSHIELD-WASHER-TANK-FEO-C650/142939471199?hash=item2147db3d5f:g:LBwAAOSwBadTqg4L:rk:11:pf:0 4 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 6, 2019 Moderators Report Share Posted February 6, 2019 There is only one picture showing one side on that bottle, quite often the pumps are on different sides..i think the one you can see is the windscreen washer pump position, the headlight pump is on the end, to the left in that pic and hidden from view.. I can't recall the orientation of the V6 bottle but perhaps hughezee can throw some light on it? 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 6, 2019 Author Administrators Report Share Posted February 6, 2019 All the pictures are on the post I linked, anyway, the one circled in red is the windscreen washer pump labelled Denso (fairly standard fitment) and the much larger one at the front circled in green is the headlight washer pump, hope that helps 😉 5 Link to comment Share on other sites More sharing options...
Randell Posted February 6, 2019 Report Share Posted February 6, 2019 Thank you, I'll sort this out on the weekend and let you all know how I got on. I've also ordered some 5 Litres of Valvoline ATF from Opie, so I'll start flushing out whatever oil is in the transmission this weekend as well. Thanks again everyone, you've been so helpful. 4 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 7, 2019 Author Administrators Report Share Posted February 7, 2019 15 minutes ago, Randell said: so I'll start flushing out whatever oil is in the transmission this weekend as well. I am taking flushing literally as your saying it which I wouldn't recommend, but all you need is to drain and refill and repeat in a few months and replace the crush washer next time p/n: 90471PX4000 https://www.coxmotorparts.co.uk/honda-shop/genuine-honda-18mm-washer/ 👍 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 7, 2019 Moderators Report Share Posted February 7, 2019 6 hours ago, hughezee said: All the pictures are on the post I linked, anyway, the one circled in red is the windscreen washer pump labelled Denso (fairly standard fitment) and the much larger one at the front circled in green is the headlight washer pump, hope that helps 😉 Thanks, !! Couldnt recall which way round it was and difficult to see pumps in pic but now you have circled them, happy days !!! 3 Link to comment Share on other sites More sharing options...
Randell Posted February 9, 2019 Report Share Posted February 9, 2019 I should have said drain and refill. No flushing. Cheers. I was hoping to do the work today but torrential rain and 50mph winds stopped play. Hopefully tomorrow will be better. Cheers. 4 Link to comment Share on other sites More sharing options...
Randell Posted February 10, 2019 Report Share Posted February 10, 2019 Well it rained, and the wind blowed a gale again, but I persevered and got the job done. Headlight washers are now working like new, and all thanks to you guys and your help. The pump casing had totally corroded and not worth trying to salvage, but the new pump I bought from the link you shared fitted, even though the body was a slightly different shape. 4 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 10, 2019 Author Administrators Report Share Posted February 10, 2019 Great work that man, great follow up much appreciated and few rep points winging there way to you 👍 3 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted February 10, 2019 Moderators Report Share Posted February 10, 2019 Well done indeed that man! Top marks for tenacity! 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 11, 2019 Moderators Report Share Posted February 11, 2019 I think that pump might just have seized then !!!!! 😆 As suspected ! Nice job and well sorted. Did you discover if you need to have the headlights on to operate it too? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 11, 2019 Author Administrators Report Share Posted February 11, 2019 7 hours ago, PTR200S said: Did you discover if you need to have the headlights on to operate it too? Only the 1998-2002 UK Accord version has that feature Pete as there's no separate button either on those, just switch on the lights flick the screen washer and they work automatically. 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 11, 2019 Moderators Report Share Posted February 11, 2019 Sorry Stu, ...do you mean 98 - 02 Accord saloon has the separate button, prior to 98 however, its on the headlights ? This thread is for 98 - 02 Coupe so i presume all separate buttons then ? 2 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 11, 2019 Author Administrators Report Share Posted February 11, 2019 Only the 1998-2002 UK Accord version has that feature where the headlights need to be on for the headlight washers to work and the coupe headlight feature was an addon so it has a button to activate them, regardless to the lights being on or off. 2 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 11, 2019 Moderators Report Share Posted February 11, 2019 Right got it , Sir, !!!! Do I have to stay for detention yet again? 200 lines of " I must pay attention when in Coupe Class." 🙃 2 Link to comment Share on other sites More sharing options...
Site Subscriber’s Chrismas Posted April 26, 2020 Site Subscriber’s Report Share Posted April 26, 2020 Useful post, just replaced the pump on mine, as it was seized. Genuine Honda one was £125 I think, and got the cheapy on Amazon, £15. Ebay only had them sourced in China, but this one was UK and arrived in 2 days. Then I forgot how the pipes went back.....and I drove over one as well, smashing one of the pipe connections. Managed to bodge it with some stiff rubber fuel pipe and used the photos here for guidance. I always forget to take pictures. Lots of plastic clips broke, too! For a 22 yr old car, there's no rust underneath either. 5 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 26, 2020 Moderators Report Share Posted April 26, 2020 Sounds good - any links to the pump on Amazon please? 3 Link to comment Share on other sites More sharing options...
Site Subscriber’s Chrismas Posted April 27, 2020 Site Subscriber’s Report Share Posted April 27, 2020 On 4/26/2020 at 7:38 PM, Laird_Scooby said: Sounds good - any links to the pump on Amazon please? https://www.amazon.co.uk/gp/product/B07RZ42GNZ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 Fitted a perfectly, despite not being the same model, so let's see how long it lasts!! I don't really think they are that effective in today's climate or in my use, as I would always wash the car regularly, but, hey, if the car has something that's not working, I like to get it working properly. Windshield Washer Pump Washer Pump Car Auto Windshield Windscreen Washer Pump for ACCORD CIVIC_ Amazon.co.uk_ Car & Motorbike.pdf 1 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 27, 2020 Moderators Report Share Posted April 27, 2020 Thanks! Added to my basket for now while i hunt down some suitable washer jets for retrofit. Given your old one needed replacing, chances are you'll find the washers are more effective now. 3 Link to comment Share on other sites More sharing options...
