Administrators hughezee Posted March 5, 2015 Administrators Report Share Posted March 5, 2015 It will cost you a lot to build a really fast Honda J35A, and it will be cheaper to buy a used BMW (or something else). But if your looking for reliability the extra express invested in J-series engine will be the sounder investment long term. Either way, to add some power, you may buy a cold air intake system, a J37A intake manifold, a J37A throttle body, Bisimoto cams, valve springs and retainers, performance headers and a 3-inch aftermarket exhaust system. Performance may be improved by head porting. Instead of your heads, you can use J32A2 heads, J32A2 pistons, and a J32A2 intake and exhaust system. In this case, only a short block will remain of your J35. All these performance parts will increase power to 320-330 HP at the flywheel. Alternatively, you can just buy a supercharger kit, install it directly on the stock internals, and get the same amount of power. Building turbo projects for obtaining 400++ HP does not make sense on the J35, its time consuming and expensive? 1 Link to comment Share on other sites More sharing options...
welland99 Posted June 8, 2015 Report Share Posted June 8, 2015 I know the 1998 -2002 Accord Coupes have the J30a engine, did any cars have a manual gearbox with a J series engine in general? 2 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted June 9, 2015 Founding Member Report Share Posted June 9, 2015 Some of the newer coupes sold in the USA are manual I believe, nothing in the UK. 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 9, 2015 Author Administrators Report Share Posted June 9, 2015 As you know personally 2.0ies models had a 5-speed option, all UK J Series are automatic, unless you fancy a manual swap 2 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted June 9, 2015 Founding Member Report Share Posted June 9, 2015 http://www.superstreetonline.com/how-to/engine/htup-1008-j-series-engine-swaps/ 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 15, 2015 Author Administrators Report Share Posted June 15, 2015 On 6/9/2015 at 1:42 PM, Cryistic said: http://www.superstreetonline.com/how-to/engine/htup-1008-j-series-engine-swaps/ Thanks for sharing Richie, hmmm ideas 🤪 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 15, 2015 Moderators Report Share Posted June 15, 2015 NSX engine swap in the Sterling doesn't sound a bad idea rather that than buy a BMW or any German car in general! 🙂🤨 1 Link to comment Share on other sites More sharing options...
DeanoCoupe Posted February 8, 2019 Report Share Posted February 8, 2019 Could you drop a J35Y4 in our Coupes with standalone ECU??? Like the idea of 300bhp 🤣🤣🤣 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 8, 2019 Author Administrators Report Share Posted February 8, 2019 16 minutes ago, DeanoCoupe said: Could you drop a J35Y4 in our Coupes with standalone ECU??? Like the idea of 300bhp 🤣🤣🤣 3.2 bits would make it more tunable as discussed before 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted February 8, 2019 Moderators Report Share Posted February 8, 2019 8 minutes ago, DeanoCoupe said: Could you drop a J35Y4 in our Coupes with standalone ECU??? Like the idea of 300bhp From what i've just read, you'd probably be better off modifying your J30 with J32 bits : http://mywikimotors.com/honda-j35/ Scroll to the bottom and you'll see what i mean. 1 Link to comment Share on other sites More sharing options...
DeanoCoupe Posted February 8, 2019 Report Share Posted February 8, 2019 Would any of those bits in isolation make improvements, like the 37 body and 32 inlet? What about the J30A4 cams? 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 8, 2019 Author Administrators Report Share Posted February 8, 2019 Will look at it in more detail but ultimately it's probably cheaper and more reliable to strip out a KB1 legend 😝 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted February 9, 2019 Moderators Report Share Posted February 9, 2019 What Stu said ^^^^^ and it would be more of a straight swap rather than a bit here, a different bit there etc. If memory serves the J35 in the Legend is about 295bhp so would almost be a "bolt-in" 100bhp ish gain. Depending on the fuel management you may not get the full power hike but even at a conservative estimate of 70% of the extra power available, you'd still be nudging 270bhp - the trouble would be finding one! 1 Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 Isn't the legend a longitudinal mounted c35a? Can that still mate up to the j30 transverse gearbox? Iirc The later gen accord coupes is the j35 transverse but you'll need to import that engine as I don't think they were ever sold here Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 15, 2019 Moderators Report Share Posted June 15, 2019 5 minutes ago, jayhoath83 said: j35 transverse but you'll need to import that engine as I don't think they were ever sold here Not in the UKDM but USAF personnel get them. 1 Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 So there wont be many if any then shame as I'd love one 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted June 15, 2019 Moderators Report Share Posted June 15, 2019 2 minutes ago, jayhoath83 said: So there wont be many if any then shame as I'd love one There's a white one on either a 17 or 68 plate and i've recently spotted either a black or midnight blue one on a 68 or 19 plate so there's a few around. 1 Link to comment Share on other sites More sharing options...
jayhoath83 Posted June 15, 2019 Report Share Posted June 15, 2019 There is hope yet then 2 Link to comment Share on other sites More sharing options...
