Andy Mc Posted May 2, 2021 Report Share Posted May 2, 2021 Is the general consensus for the standard down turned tips, to cut them before fitting aftermarket trim? Or do they work just straight on despite the downward angle? 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 3, 2021 Author Moderators Report Share Posted May 3, 2021 7 hours ago, Andy Mc said: Is the general consensus for the standard down turned tips, to cut them before fitting aftermarket trim? Or do they work just straight on despite the downward angle? I cut mine down so that they fitted snugly and went nearly back to the silencer. If i had not cut the pipe they looked like they were just bolted on ends rather than looking like the original pipe 😁 I guess it depends on how long the tips are, the 2" shorty stuff looks shit imo. Looks OK from above but stand back a few feet from the rear and you can see they are just bolt on end pipes 😉 Psst, I did a lot of measuring before I cut my pipes.....didn't want to have to weld anything back on !!! 🤣🤣🤣 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 25, 2022 Author Moderators Report Share Posted April 25, 2022 I put new tips on in March 2017, spun alloy type ....its now 5 years on and this is how they look now... Well pleased ! 3 Link to comment Share on other sites More sharing options...
Andy Mc Posted April 30, 2022 Report Share Posted April 30, 2022 I still neeeed some of these 1 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 30, 2022 Author Moderators Report Share Posted April 30, 2022 6 hours ago, Andy Mc said: I still neeeed some of these Have a look at these, right size but these are chromed version rather than the satin finish.. https://www.ebay.co.uk/itm/165225957509 I also chose the slash cut type, these are straight cut. Anything this size will look good unless you want the "bucket " look 😲 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 1, 2022 Author Moderators Report Share Posted May 1, 2022 1 hour ago, Chrismas said: 3 bolts to hold the tip in looks excessive. Mine has only one bolt, and is at the bottom, so for most of the time, that bolt is hidden. Quite right it's excessive !!!!!!! It's only to ensure it sits central on the pipe, usually to keep a small exhaust pipe looking somewhat less crap !!!!! The bigger exhaust diameter the better, to fill the tip internal diameter, then you can as you say, use less bolts. Not only that , if the pipe actually fills the tip then it looks aesthetically better too. I have always tried to find a tip that is the "correct" diameter and left out a couple of the bolts if they were even there to start with !!!! 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted October 28, 2022 Administrators Report Share Posted October 28, 2022 I decided it was time for a change and replaced my 7th gen tips, re-using the exhaust tips from Kelvins' former motor. 2 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted October 28, 2022 Author Moderators Report Share Posted October 28, 2022 Blimey your motor runs hot !! They have turned blue !!! I like the oval look. 👍👍 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted October 28, 2022 Administrators Report Share Posted October 28, 2022 4 hours ago, PTR200S said: your motor runs hot !! 1 Link to comment Share on other sites More sharing options...
Site Subscriber’s Kelvin Posted October 29, 2022 Site Subscriber’s Report Share Posted October 29, 2022 21 hours ago, hughezee said: I decided it was time for a change and replaced my 7th gen tips, re-using the exhaust tips from Kelvins' former motor. Look much better on a lighter coloured car 👍 4 Link to comment Share on other sites More sharing options...
