Moderators PTR200S Posted August 16, 2020 Moderators Report Share Posted August 16, 2020 Caliper back on, pads in of course ! As a note, the piston was screwed in another half turn to take account of the worn disk...new disk takes up the slack !! More BH UC applied up here too ! Wheel back on, test for operation, yep all good !! This came out of the rear arches... good shovel full....and I think I keep it pretty clean under here but this stuff was in all the orifices I can't get to without taking the wheels off. 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted August 17, 2020 Administrators Report Share Posted August 17, 2020 Great work on the brakes Pete 👍 4 1 Link to comment Share on other sites More sharing options...
Site Subscriber’s Chrismas Posted August 27, 2020 Site Subscriber’s Report Share Posted August 27, 2020 On 6/20/2020 at 10:07 PM, PTR200S said: Fixed the light in the clock, today, genuine Honda bulb, only three years since I started the job 🙄 Remembered to insert the clock top first 🙂 Sat in the scrumptious smelling leather,,,,,need another go at it whilst its clean !!! Tomorrows job I reckon. where did you get the bulb from? I found a few on eBay, but they were a right faff to fit, and not very bright either. 3 Link to comment Share on other sites More sharing options...
Site Subscriber’s Chrismas Posted August 27, 2020 Site Subscriber’s Report Share Posted August 27, 2020 On 6/24/2020 at 6:59 PM, Vibesy said: Got my Coupe back today as my brother had borrowed it as his car was off the road so I thought I would treat Dotty to a lot of love and attention 😁 Looks good in green! Most seem to be in silver including mine. 4 Link to comment Share on other sites More sharing options...
Site Subscriber’s Chrismas Posted August 27, 2020 Site Subscriber’s Report Share Posted August 27, 2020 Since owning my Coupe (May 2019) I've done nothing to it mechanically, other than an oil change. But I've been getting a bit of hesitation and a lumpy idle on first start up. So on checking the ignition system, I find that all 6 spark plugs are only screwed in, barely hand tight! So these came out and got a clean. They were in good condition though. Then a look at the dizzy and rotor arm, both of which had seen better days. I've cleaned them up, and refitted, but have some new ones on order. Anyway, it idles nicely now, and rises to about 1200 rpm on a cold start. Nice! 2 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted August 27, 2020 Moderators Report Share Posted August 27, 2020 4 hours ago, Chrismas said: where did you get the bulb from? I found a few on eBay, but they were a right faff to fit, and not very bright either. Ended up importing it from the States....they should have been available from UK dealers but they were either too expensive and/ or didn't have any stock anyway !! Part no 35505-S84-N01 2nd page on here; 3 Link to comment Share on other sites More sharing options...
welland99 Posted August 28, 2020 Report Share Posted August 28, 2020 On 8/16/2020 at 6:26 PM, PTR200S said: bit of corrosion here !! Very good report on the brake service, Pete. The disc in your photo didn't look too bad to me, I've seen much worse. What were the pads like? How old (time & mileage) were the discs and pads? 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted August 29, 2020 Moderators Report Share Posted August 29, 2020 The pics don't really show the extent of the damage, pretty lumpy and the actual disk thickness of the good bit was at minimum recommended thickness too. Hence having to screw the piston in another half turn. The original discs I removed were genuine Honda disks, probably the original factory ones but as it was a one owner car with full service history it may have had new ones from the dealer......87k miles After I had trouble in January/ February this year with seized calipers and delamination of the pads I cleaned up this disks and put new Honda pads in. Pics on earlier in this thread. This improved it no end but I knew that I would have to replace them eventually. I cleaned up the Jan / Feb Honda pads from last time and reused them this time too.. so have a spare set of new honda pads in stock ! 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 6, 2020 Administrators Report Share Posted September 6, 2020 I have purchased a new harmonic balancer as the rubber is cracking on mine and I have promised myself the Accord coupe will be back on the road by October, not all the jobs will be done but a few new ones at least... 4 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted September 7, 2020 Moderators Report Share Posted September 7, 2020 13 hours ago, hughezee said: I have purchased a new harmonic balancer as the rubber is cracking on mine and I have promised myself the Accord coupe will be back on the road by October, not all the jobs will be done but a few new ones at least... Have you got a bit of a wobble on or has your rubber come adrift then ?? !! 😄 1 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 7, 2020 Administrators Report Share Posted September 7, 2020 10 hours ago, PTR200S said: Have you got a bit of a wobble on or has your rubber come adrift then ?? !! 😄 Na its still good, so it goes in the spares pot if anybody needed one, member Dave was lucky recently, every part his coupe needed to get back on the road I had one. 4 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 27, 2020 Administrators Report Share Posted September 27, 2020 Today I actually started to put the coupe back together (interior wise) but I couldn't resist a quick start-up and as soon as it fired into life, I heard noises like somebody dragging an anchor and chain along the floor it was promptly shut off, shat myself was an understatement 😆. The suddenly realized I hadn't put the brakes back together oops 😒 Also, rock auto has kindly ragged my wallet again, updates to follow 🤪 3 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted September 27, 2020 Moderators Report Share Posted September 27, 2020 43 minutes ago, hughezee said: Also, rock auto has kindly ragged my wallet again, updates to follow 🤪 Looking forward to that ! ! ! They nearly raped my wallet yesterday as well, it was the S&H that killed it on one particular item (rear brake disc/drums) though and i managed to find what i needed on fleabay and take advantage of the 20% discount fleabay was offering on items over £15 so got the disc/drums cheaper. 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted October 7, 2020 Administrators Report Share Posted October 7, 2020 Well I finished off the coupe (for now) and it is ready for MOT tomorrow and if it passes without a hitch, I will be fitting new timing belt, water pump, tensioner, aux belts, new alternator etc etc you get the idea 🤪 3 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted October 7, 2020 Moderators Report Share Posted October 7, 2020 Good luck for the test Stu! 👍 2 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted October 8, 2020 Moderators Report Share Posted October 8, 2020 👍 Good luck from over here too ! I don't think you need any luck though, i am sure you have all the skill you need to get a clean pass😁 2 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted October 8, 2020 Administrators Report Share Posted October 8, 2020 Thanks chaps, MOT'd & TAXED nice cruise on the cards now 😎 4 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted October 18, 2020 Administrators Report Share Posted October 18, 2020 Screenwash topped up and new oil filter and coupe cruise tonight, ran sweet as a nut 😁 2 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted October 21, 2020 Moderators Report Share Posted October 21, 2020 Fluid check day , all good plus a full reservoir quantity of PS fluid extracted and replaced with Mr Honda finest,,,got a few bottles to go through before moving onto something better.... While I was at it did the Elysion and sil Tourer too !! 3 Link to comment Share on other sites More sharing options...
Graymalkin Posted October 21, 2020 Report Share Posted October 21, 2020 Topped up fluids and oil. Cleaned wipers and replaced mats after a wash. (after getting cat poo on them) 5 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted October 21, 2020 Administrators Report Share Posted October 21, 2020 21 minutes ago, Graymalkin said: Topped up fluids and oil. Cleaned wipers and replaced mats after a wash. (after getting cat poo on them) Great to hear from you Richard 😁👊👍 1 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted October 21, 2020 Moderators Report Share Posted October 21, 2020 What Stu said ^^^^^! Thought i recognised the screnname but couldn't work out why and why it wasn't as familiar as it should have been! Good to see you back! 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted October 22, 2020 Administrators Report Share Posted October 22, 2020 Think I have a problem, buying bits for my coupe again... 🤪 1 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted October 22, 2020 Moderators Report Share Posted October 22, 2020 "My name is Stu and i'm a shopaholic!" Don't worry Stu, we're all guilty of the same, just varies in the amount we spend! 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted October 23, 2020 Moderators Report Share Posted October 23, 2020 mm mm ,, filters....mmmm, oil 🤣 I can't get enough !!! Hoarding officer moi? Mais non !!!! 2 Link to comment Share on other sites More sharing options...
