Gazz Posted February 19, 2022 Report Share Posted February 19, 2022 After replacing the battery with the +Ve terminal apparently fully tightend and miles of driving later the arlarm suddenly decides to sound on unlocking the doors with the remote. I found that the +ve terminal was loose due to the post being slightly under sized which I have packed with some lead to ensure a firm connection. The fault is still there various efforts at unlock relock key lock in door ignition on it would silence but start sounding again. Even with the engine running! I have removed the siren connector for now. Does anyone have any idea what this may be or how to diagnos it and how to fix it? 3 Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted February 19, 2022 Founding Member Report Share Posted February 19, 2022 I wonder if there is any corrosion on the terminals of the remote receiver such that the signal to unlock is received and is sent to the unlock mechanism and the immobiliser but not the siren side of the anti theft system. Or perhaps the receiver itself has become faulty... if the latter, pulling the terminal (or providing a steady 12v supply) depending on whether or not it needs the presense or absense of 12v to sound the siren should also work 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 20, 2022 Administrators Report Share Posted February 20, 2022 Sorry to hear of your troubles, what paul has suggested is spot on, it could be a sensor? Instead of chucking parts at it maybe getting an auto electrician to trace the fault they even might be able to see what the system is saying regards open circuit on a key component? 2 Link to comment Share on other sites More sharing options...
Site Subscriber’s RevvinKevin Posted February 20, 2022 Site Subscriber’s Report Share Posted February 20, 2022 I had a similar issue but hadn't touched or replaced anything on the car. The only thing I may have done was to hit a random combination of keyfob button presses, due to me having my hands and arms full trying to carry too much. My issue stopped the same day though and has not reoccurred since. Hope you sort your issue quickly and cheaply 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted February 21, 2022 Moderators Report Share Posted February 21, 2022 If the +ve terminal has become loose due to a size discrepancy, chances are so has the -ve terminal. You may have to replace the terminal clamps to achieve a repair. Link to comment Share on other sites More sharing options...
Gazz Posted February 27, 2022 Author Report Share Posted February 27, 2022 Hi everyone thanks for your thoughts. I'm not sure where any of the sensors are nor how I would access them. Having driven with the siren disconnected the for a while (my simple fix) the immobiliser has now kicked in and the dash lights up but no ignition. Can anyone recommend an auto electrician that would know the Legend wiring? 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 20, 2022 Administrators Report Share Posted March 20, 2022 On 2/27/2022 at 5:26 PM, Gazz said: Can anyone recommend an auto electrician that would know the Legend wiring? So sorry I missed this ☹️ hope you got it sorted... 🤞🏼 1 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted December 30, 2022 Founding Member Report Share Posted December 30, 2022 I've had the same happen tonight, drove to my friends house fine, came out 5 min later to drive to the Pub (I was driving) and the siren was constantly going of while driving. After a what felt like a long drive home where the times between alarms would vary, I got home, checked all the doors and boot were close properly and locked the car, no more alarm for at least 15 min. As soon as I unlock the car the alarm goes off for a minute or so, then stops. By this point I have the bonnet up as well and the alarm has stopped, which I found odd as I thought it would carry on with the bonnet open. I've disconnected the battery now and I'll look at it in the morning, good job I have 10 days of warranty left, any advice on how to disconnect the siren @hughezee? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 30, 2022 Administrators Report Share Posted December 30, 2022 Sounds like the batteries need replacing in the siren unit, that's assuming it shares a similar system with other Hondas of the same vintage. The only snag is the replacement batteries are difficult to get hold of these days. As it is a relatively cheap fix if you can find the replacement battery(s) especially if you're handy with a soldering iron. Most of the time I just remove the siren unit with no real consequence as the immobilizer system will still function.🖐️ 2 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted December 30, 2022 Founding Member Report Share Posted December 30, 2022 Quick question, is the car supposed to beep the horn when you lock it, mine locks but makes no noise 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 30, 2022 Administrators Report Share Posted December 30, 2022 1 minute ago, Cryistic said: Quick question, is the car supposed to beep the horn when you lock it, mine locks but makes no noise Not that I am aware of, some cheap Mercs do it. 😆 3 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted December 30, 2022 Founding Member Report Share Posted December 30, 2022 This type? https://cellpacksolutions.co.uk/products/batteries/gp-batteries-gp320bvh6a6-siren-alarm-box-sab-battery/ The terminals were not really tight when I disconnected the negative, I'll leave the battery off for 24 hours then see what happens after that. 2 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted December 31, 2022 Founding Member Report Share Posted December 31, 2022 It's back at the dealers for a few days for them to check over the Alarm (which was fine this morning after reconnecting the battery 🙄) and check the steering rack to see if I'm paranoid or there is a problem. IT's £275 to extend the RAC warranty for another year, I think that it might be a wise investment. 4 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted January 5, 2023 Founding Member Report Share Posted January 5, 2023 Apparently I'm paranoid with regards to the steering rack😁 The alarm hasn't misbehaved again, they checked the catches on the car to see if one wasn't registering as closed, no residual codes were stored so it seems like it was just having a bit of a moment, I've put a new battery in the main key as well. So now I wait till it decides to throw a hissy fit again, ahh well I'll keep a set of earplugs in the car. 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted January 5, 2023 Moderators Report Share Posted January 5, 2023 Maybe not paranoia if the dealer is telling porkies that they can't find anything wrong ..... Do you still feel the steering isn't as it should be ??? 2 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted January 6, 2023 Founding Member Report Share Posted January 6, 2023 They are getting paid by the warranty company to fix it, not me and they will be doing the MOT later in the year as well. I think after the over assisted Lexus and Volvo steering it just feels a little heavy at low speeds, once moving it weights up nicely and the LKAS is working as it should so I think it's more me worrying rather than an actual fault. Newman and Reidy have been around for years with a good reputation locally, all they guys have worked there for years which I think is a good sign at any Dealer. 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted January 6, 2023 Moderators Report Share Posted January 6, 2023 If you have good relations with that dealer and they have a good reputation then that's encouraging, novel in this day and age too finding a good garage !!! I have had that feeling sometimes, re steering, jumping into different cars !!! " Why does this feel odd " !!!! Electric assisted steering is a real oddball, the two Jazz we run, with two years between them , one is light steering (04plate ) whereas the 06 plate is much heavier/ stiffer...both check out fine. I recall my S2000 was strange when I first got it, another electric rack as it happens,,,,,,very much acquired taste, much prefer the hydraulic stuff. Good news though if everything checks out on yours, you can just drive it now !!!! 2 Link to comment Share on other sites More sharing options...
