Administrators hughezee Posted January 17, 2016 Administrators Report Share Posted January 17, 2016 Couple of shots of me removing a 1999 Accord Coupe door card, gain access to door speaker, exterior handle, lock & actuator or the window regulator mechanism If your struggling to get the door card back on, make sure all cables are clipped back in place and check the internal lock release (pictured above) is lined up with the hole at the top and the card should hang on the edge by the window and should slot down snug Any questions please ask us 3 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted January 20, 2016 Founding Member Report Share Posted January 20, 2016 Great write up as usual. 1 Link to comment Share on other sites More sharing options...
UrbexRobby Posted July 17, 2017 Report Share Posted July 17, 2017 Always one numpty cant seem to fit ky edge speakers in door lol Link to comment Share on other sites More sharing options...
welland99 Posted July 23, 2017 Report Share Posted July 23, 2017 Do you get any draft from around the electric window switches while driving? I have been aware of quite a draft from around my drivers window switches, and I put it down to a poor seal between the door and the film that fits behind the door card. I have worked on my drivers window regulator a few times and may be guilty of a sloppy job refitting the aforementioned film. Link to comment Share on other sites More sharing options...
Mangoman Posted July 23, 2017 Report Share Posted July 23, 2017 Still after one of those little grommets that cover the screw in the Door Handle Recess..... Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted July 23, 2017 Moderators Report Share Posted July 23, 2017 23 minutes ago, Mangoman said: Still after one of those little grommets that cover the screw in the Door Handle Recess..... Join the club, one out of my drivers door too Link to comment Share on other sites More sharing options...
Mangoman Posted July 23, 2017 Report Share Posted July 23, 2017 2 minutes ago, PTR200S said: Join the club, one out of my drivers door too I reckon they are most probably quite generic to Honda - have to go down the local Silverlake sometime and grab one... Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted July 23, 2017 Moderators Report Share Posted July 23, 2017 4 minutes ago, Mangoman said: I reckon they are most probably quite generic to Honda - have to go down the local Silverlake sometime and grab one... Wonder what Honda call them ? Screw cap, ? Cover? Plug? Or, as you say, gromet? Must be a part number for them Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted July 23, 2017 Moderators Report Share Posted July 23, 2017 Just found on lings...called a "cap,case." Two types available at 5 quid each ! Edit Here honda part numbers 72126sm4003 zn grey Same number again suffix with zr gives beige. Apparently the 2004 Odyssey had them and the accord saloon, US version i guess. 1 Link to comment Share on other sites More sharing options...
Lumpy Posted February 19, 2019 Report Share Posted February 19, 2019 Lings are easy to order from though 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 19, 2019 Author Administrators Report Share Posted February 19, 2019 A couple of casualties from removing the door cards, good man for replacing them instead of bodging it 👍👍 2 Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted February 21, 2019 Founding Member Report Share Posted February 21, 2019 On 2/19/2019 at 3:07 PM, Lumpy said: Lings are easy to order from though Are those the caps within the door release handle ? If so how much were they if you don’t mind me asking? 2 Link to comment Share on other sites More sharing options...
Lumpy Posted February 22, 2019 Report Share Posted February 22, 2019 22 hours ago, AhsyV6 said: Are those the caps within the door release handle ? If so how much were they if you don’t mind me asking? Yes they are, I think they were 3.46 each, plus delivery if you aren't picking them up. The invoice is at work. Look on Lings website for them. https://www.lingshondaparts.com/partscatalog/catalog/listing/catalog/hondacars/modelid/417/block/17S8201/blockref/B__5310/ no idea why it's in Euros. Item 13. 1 Link to comment Share on other sites More sharing options...
Lumpy Posted February 22, 2019 Report Share Posted February 22, 2019 On 2/19/2019 at 3:48 PM, hughezee said: A couple of casualties from removing the door cards, good man for replacing them instead of bodging it 👍👍 casualties before me I'm pleased to say. 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 22, 2019 Moderators Report Share Posted February 22, 2019 58 minutes ago, Lumpy said: Yes they are, I think they were 3.46 each, plus delivery if you aren't picking them up. The invoice is at work. Look on Lings website for them. https://www.lingshondaparts.com/partscatalog/catalog/listing/catalog/hondacars/modelid/417/block/17S8201/blockref/B__5310/ no idea why it's in Euros. Item 13. Yes, that's right, its the ones I mentioned further up the thread "cap case" but I just quoted the Honda part number not the Lings one, sorry ! Currently showing at 4.61 or 5.15 each depending on colour on the Lings site, £9.22 including tax for the two in grey or £10.30 for the beige version including tax but the postage is £4.50 ??? is that right ??? 😲 1 Link to comment Share on other sites More sharing options...
Lumpy Posted February 22, 2019 Report Share Posted February 22, 2019 3 minutes ago, PTR200S said: Yes, that's right, its the ones I mentioned further up the thread "cap case" but I just quoted the Honda part number not the Lings one, sorry ! Currently showing at 4.61 or 5.15 each depending on colour on the Lings site, £9.22 including tax for the two in grey or £10.30 for the beige version including tax but the postage is £4.50 ??? is that right ??? 😲 regrettably yes, it must have been the other clips that were cheaper. Yes for what they are they are damn expensive but worth it, just. Find a local Honda dealer and pick them up 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 22, 2019 Moderators Report Share Posted February 22, 2019 19 minutes ago, Lumpy said: damn expensive but worth it, just. 😛 agreed !! finishing touches ! 2 Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted February 22, 2019 Founding Member Report Share Posted February 22, 2019 Thanks for link.....I’ve been referring to this site for about 10 years now but have never bought from it. I’ve just signed up and made an account however I can’t order anything or work out how to order. I’m on an iPhone.....any ideas? 2 1 Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted February 22, 2019 Founding Member Report Share Posted February 22, 2019 Ignore that.....it would help if I swiped across!!!! 3 Link to comment Share on other sites More sharing options...
