leyton72 Posted December 18, 2022 Report Share Posted December 18, 2022 Managed to put some sealant in the boot gutter of both coupe yesterday (before it started raining). The leaks in the blue coupe was quite bad in the boot, the water got collected in the plastic trays at the side and got iced over so was easy to clean, just had to get the block of ice out 😂🤣. I checked the boot after it started raining and it seems to have done the job. Will have to wait for torrential rain to really find out if the seals are holding well 🤞. 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 19, 2022 Administrators Report Share Posted December 19, 2022 On 12/18/2022 at 12:11 PM, leyton72 said: Managed to put some sealant in the boot gutter of both coupe yesterday (before it started raining). Great work 👍 any pic's 🤞 2 Link to comment Share on other sites More sharing options...
welland99 Posted January 8, 2023 Report Share Posted January 8, 2023 I'm getting water in the boot, but not through the gutter seals. It is leaking into the boot lid cavity. When I open the boot, the water leaks out the edges and runs off the bolts which hold the rear light. Then, when I close it, it runs out from behind the boot lid trim on the rear lower edge. I think the water is getting into the boot lid cavity through a degraded seal between the rear light (the combined fog light and reverse light) and the boot lid. I seem to recall a very old thread in the old forum about removal and refitting the fog & reverse light to solve water ingress in this path, but I cant find it now. Is it still in the archives? 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted January 8, 2023 Moderators Report Share Posted January 8, 2023 9 hours ago, welland99 said: I'm getting water in the boot, but not through the gutter seals. It is leaking into the boot lid cavity. When I open the boot, the water leaks out the edges and runs off the bolts which hold the rear light. Then, when I close it, it runs out from behind the boot lid trim on the rear lower edge. I think the water is getting into the boot lid cavity through a degraded seal between the rear light (the combined fog light and reverse light) and the boot lid. I seem to recall a very old thread in the old forum about removal and refitting the fog & reverse light to solve water ingress in this path, but I cant find it now. Is it still in the archives? Have a look here ???? Is this the thread you are thinking about ? 3 Link to comment Share on other sites More sharing options...
welland99 Posted January 9, 2023 Report Share Posted January 9, 2023 14 hours ago, PTR200S said: Have a look here ???? Is this the thread you are thinking about ? Thanks Pete, that's the one. 2 Link to comment Share on other sites More sharing options...
