Pete205 Posted February 28, 2023 Report Share Posted February 28, 2023 Today I got my Honda over a pit to see where the power steering fluid was raining from… hmm… not good news as the bottom high pressure pipe to the steering rack has a hole in it & so far I’ve been unable to find a replacement online. It was too late to call the Honda dealer so I’ll continue to search online this evening & call tomorrow. If anyone knows of where I might find such a thing I’d appreciate it. Meanwhile I’m crossing my fingers (except when I’m typing)…. Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 28, 2023 Administrators Report Share Posted February 28, 2023 Hi and welcome back, sorry to hear of your troubles with the power steering and I am sure I might be able to assist with a replacement part. However, since you've never properly introduced yourself or your car is it a 2.0 or 3.0 V6 and could you confirm the accurate location of the leak? I only ask as they're are a few pipes and the lower sections are low pressure and the larger upper hose section is high pressure. 1 Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted February 28, 2023 Founding Member Report Share Posted February 28, 2023 Might be worth approaching a local hydraulics specialist shop to see what they can offer. In Manchester I use Able Hydraulics, https://www.ablehydraulics.co.uk/ They can copy, make or mend most hydraulics stuff.... 2 Link to comment Share on other sites More sharing options...
Harry93 Posted February 28, 2023 Report Share Posted February 28, 2023 1 hour ago, Pete205 said: Today I got my Honda over a pit to see where the power steering fluid was raining from… hmm… not good news as the bottom high pressure pipe to the steering rack has a hole in it & so far I’ve been unable to find a replacement online. It was too late to call the Honda dealer so I’ll continue to search online this evening & call tomorrow. If anyone knows of where I might find such a thing I’d appreciate it. Meanwhile I’m crossing my fingers (except when I’m typing)…. Apart from UK dealers you can try aftermarket, but that is if you are willing to wait for international delivery. If it's the pressure hose try RockAuto or HondaPartsNow.com 1 Link to comment Share on other sites More sharing options...
Pete205 Posted February 28, 2023 Author Report Share Posted February 28, 2023 Thanks for the advice I’ll give them a look Link to comment Share on other sites More sharing options...
Pete205 Posted February 28, 2023 Author Report Share Posted February 28, 2023 24 minutes ago, hughezee said: Hi and welcome back, sorry to hear of your troubles with the power steering and I am sure I might be able to assist with a replacement part. However, since you've never properly introduced yourself or your car is it a 2.0 or 3.0 V6 and could you confirm the accurate location of the leak? I only ask as they're are a few pipes and the lower sections are low pressure and the larger upper hose section is high pressure. Hi there apologies for not introducing myself properly I’m Pete I live in Sheffield & have a 1998 3litre v6 accord coupe with a corroded bottom pipe of the two that go to the steering rack. At the garage where the pit was the mechanic said it was a high pressure pipe which is why I’ve stated that in my previous post. I’m grateful for any help in this situation. 1 Link to comment Share on other sites More sharing options...
Pete205 Posted February 28, 2023 Author Report Share Posted February 28, 2023 34 minutes ago, hughezee said: Hi and welcome back, sorry to hear of your troubles with the power steering and I am sure I might be able to assist with a replacement part. However, since you've never properly introduced yourself or your car is it a 2.0 or 3.0 V6 and could you confirm the accurate location of the leak? I only ask as they're are a few pipes and the lower sections are low pressure and the larger upper hose section is high pressure. Looking at the diagram I’d say 16 is the most likely contender 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 28, 2023 Administrators Report Share Posted February 28, 2023 31 minutes ago, Harry93 said: If it's the pressure hose try RockAuto or HondaPartsNow.com Good suggestion but they will likely only have the LHD version as the connections are different on RHD 17 minutes ago, Pete205 said: Thanks for the advice I’ll give them a look 1 Link to comment Share on other sites More sharing options...
Pete205 Posted February 28, 2023 Author Report Share Posted February 28, 2023 34 minutes ago, PaulS said: Might be worth approaching a local hydraulics specialist shop to see what they can offer. In Manchester I use Able Hydraulics, https://www.ablehydraulics.co.uk/ They can copy, make or mend most hydraulics stuff.... Many thanks for your suggestion 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 28, 2023 Administrators Report Share Posted February 28, 2023 39 minutes ago, Pete205 said: Looking at the diagram I’d say 16 is the most likely contender This is a low-pressure line and could be repaired with a section of copper pipe reusing the hydraulic union to the rack, I have done it many times on Hondas in general. 1 Link to comment Share on other sites More sharing options...
Pete205 Posted February 28, 2023 Author Report Share Posted February 28, 2023 31 minutes ago, hughezee said: This is a low-pressure line and could be repaired with a section of copper pipe reusing the hydraulic union to the rack, I have done it many times on Hondas in general. Thankyou kindly for your expertise I feel a lot better now I know about some options 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 28, 2023 Administrators Report Share Posted February 28, 2023 1 hour ago, Pete205 said: Thankyou kindly for your expertise I feel a lot better now I know about some options This was for another Honda with the same age-related issue, just to you give you an idea.😉 1 Link to comment Share on other sites More sharing options...
Pete205 Posted February 28, 2023 Author Report Share Posted February 28, 2023 24 minutes ago, hughezee said: This was for another Honda with the same age-related issue, just to you give you an idea.😉 Marvellous thank you very much 2 Link to comment Share on other sites More sharing options...
