Elysion 2006 2.4 Aftermarket / Replacement Radiator?
Hello chaps,
Long time scanner of the useful forum articles, but new signer-upper!
Currently have a 2006 Honda Elysion 2.4 Auto in pearl white. (Since 2017)
It is a spare "work" vehicle and hasn't been used very much for the past year. Upon bringing it back into action, I did a couple hundred mile journey and eventually noticed steam / a slight leak from the top of the radiator.
If the good old rad weld doesn't do the job, is there anywhere to source a replacement radiator that fits? Cannot seem to find anything.
Much appreciated.
Farley.
  • Like 3
Link to comment
  • Moderators
Funnily enough just asked that question about usage in the newb intro so got my answer now !!! 🙄😛
I would be wary of radweld / similar, although they have around forever there is concern about waterpumps and associated water ways, particularly narrow feeds say to intake manifolds,  getting blocked. I view the stuff as a temporary solution at best.
Re getting the rad actually sorted, is it the top tank seal that has split ??
Do you have a lot of pressure build up in the rad?? Is the rad cap valve OK?
A replacement radiator is plus 700 quid,  quite expensive , but having it repaired and pressure tested by a local rad company is probably your best bet and a lot cheaper......assuming you establish the reason for leakage is just corrosion let's say rather than over pressure from maybe a stuck closed thermostat which is unusual. Or a rad cap problem...hopefully not a head gasket leak....
Link to comment
  • Moderators
Please don't even consider using Radweld in it! I'm not 100% sure about your engine but Radweld used to carry a warning that it wasn't to be used in mine or Legend models because it clogs important coolant channels around the throttle body that effect the fsat idle when cold (giving you a fast idle when hot! :o ) and other worse things.
Much better to find somewhere to repair the rad or find another good one from  somewhere, possibly another model as long as it's a similar size and cooling capacity.
Link to comment
  • Administrators
My guess your radiator is a : 19010-RKC-901 OR 19010-RKC-902 which both refer to DENSO 422000-6821 OR NISSENS HD1058 OR ASSIN B07DLT1KPJ
https://autoparts.beforward.jp/detail/Cooling-Components/Radiators/PA33206766/
  • Like 3
Link to comment
  • 1 month later...
  • 6 months later...
Hi all,
So the Elysion has been sat in storage for a while, unfortunately I did not have much time lately, so this got put on hold.
However on Saturday I did the job and took the rad off. It was unbelievably over complicated to get the damn thing out.
Cowling covers off, air intake pipe off, front grill off, air con rad separated, bonnet latch mech removed, two fans unbolted and unclipped, plugs to remove all over the place and cable tie clips with wires etc. And hardly any room to move about.
There were also two unexpected lines that connect to the bottom of the rad I assume something to do with the auto transmission.
Anyway, I got in touch with Huddersfield rads and they had half hour getting some info on the rad before calling me back.
They said a lot of imports have issues that the top or bottom plastic tanks get brittle and crack over time. Like mine has.
In the end they said they would have to make a custom rad from scratch most likely. Now I would say this sounds great in theory but I am a bit apprehensive that this rad has to match perfectly to fit in the small tolerances and the fact they there is a ledge all around for the ac rad to sit on and various mounting points required for the 2 fans and the a/c rad to bolt onto.
I thought I would give Honda a call, they managed to find the oe rad part and told me that they were £677.00 but that they are now discontinued from manufacture and no stock is available. So a new oe rad is out of the question.
Since I last posted, has anyone had any more experience regarding aftermarket parts / a blueprint that will do the job for me before having to make a custom rad.
Some of these readily available Odyssey rads looks near perfect and I was wondering if the 2.4 setup on an Elysion is identical to any other Honda models... I have asked Mishimoto also as they seen to have a stock of all sorts of Honda rads.
Cheers, Farley!
Link to comment
My radiator is part 19010-RKC-901
I called Nissens directly and they told me that isn't a valid reference for them although I got in touch with that company with HD1058 listed on the web (awaiting response), then I got in touch with ARKS Global Ltd and they cross checked all the references and hit a brick wall with no results.
Proving to be rather tricky.
  • Sad 2
Link to comment
  • Administrators
🙃 it seems I got a part identifier number confused with an OEM part number, my apologies, I hope they get back to you with some availability at a reasonable cost.🤞🏼
Link to comment
  • 6 months later...
Just a heads up, I was lucky enough to find a jdm breaker of the same model but 5 years newer near Dover.
The only other options were:
- To import a used radiator from a japan based breaker for about £5-700 to the uk landed.
- Get a custom radiator made, quoted about 500 but it wouldn't have fitted as well as the original as it wouldn't have had all the fans mounting points and a/c rad ledge with mounting points, plus there is hardly any room once all of that is installed, so it would have been a bit risky.
- Or I did find a UK jap parts company with a brand new honda oem one for approx £1250 they wanted. (only one I could source in the whole of the uk.)
  • Like 2
Link to comment
