Administrators hughezee Posted December 25, 2016 Administrators Report Share Posted December 25, 2016 As a follow up to past discussions regarding Coolant/ Antifreeze and the problems associated with using Honda Type 2 Coolant p/n: 08CLAG026L0 when used in older engines, which results in annoying leaks, vapour leaks and really unpleasant persistent odours (also requires replacement every 2 years). Although these symptoms from using Type 2 coolant can be elevated with some water dilution to the 50/50 mix up to 65% water to 35% coolant mix, improving the heat exchange process. So I have illustrated one of the most common fluids used by myself or recommended by other members, so if you are looking for a standard fluid to TOP-UP you can use Honda Type 2 Coolant, but try avoid using large amounts i.e flushing the cooling system after maintenance or repairs on the cooling system (you have been warned). Owners looking for great protection or one stop solution or just a TOP-UP I would highly recommend Prestone Coolant Antifreeze. 👍 PLEASE NOTE: the information within this topic has been kindly contributed by one of our experienced members and has been extensively researched and found to be correct by independent testing or external resources. However' when replacing radiators and water pumps, some manufacturers insist on genuine coolant for warranty purposes, please adhere to this advice. Regards SITE DEVELOPMENT. 3 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted December 25, 2016 Founding Member Report Share Posted December 25, 2016 Thanks for the info Stu as I need change my timing belt and water pump. 2 Link to comment Share on other sites More sharing options...
KingK0ng Posted December 21, 2019 Report Share Posted December 21, 2019 What's wrong with Honda type 2 coolant ? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 21, 2019 Author Administrators Report Share Posted December 21, 2019 2 hours ago, KingK0ng said: What's wrong with Honda type 2 coolant ? Caused me nothing but trouble over the years, leaks big or small either way the car stinks of coolant even without any visible leaks... 1 1 Link to comment Share on other sites More sharing options...
KingK0ng Posted December 21, 2019 Report Share Posted December 21, 2019 32 minutes ago, hughezee said: Caused me nothing but trouble over the years, leaks big or small either way the car stinks of coolant even without any visible leaks... Where did you notice those leaks ? Is this coolant too thin or something ? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 21, 2019 Author Administrators Report Share Posted December 21, 2019 46 minutes ago, KingK0ng said: Where did you notice those leaks ? Is this coolant too thin or something ? its the content mix, leaks around hoses radiator caps, thermostat housings, water pump seals, literally every old honda I've used it in it has leaked in some shape or form and it stinks when its in a warm engine bay 🤢 2 1 1 Link to comment Share on other sites More sharing options...
KingK0ng Posted December 21, 2019 Report Share Posted December 21, 2019 5 minutes ago, hughezee said: its the content mix, leaks around hoses radiator caps, thermostat housings, water pump seals, literally every old honda I've used it in it has leaked in some shape or form and it stinks when its in a warm engine bay 🤢 I use Type 2 coolant byt didn't notice something yet. I'll be watching this carefully. What do you use now ? 4 Link to comment Share on other sites More sharing options...
Founding Member Retro Rich Posted December 21, 2019 Founding Member Report Share Posted December 21, 2019 4 hours ago, hughezee said: Caused me nothing but trouble over the years, leaks big or small either way the car stinks of coolant even without any visible leaks... Little bit in the expansion bottle won’t hurt 😉 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 22, 2019 Author Administrators Report Share Posted December 22, 2019 8 hours ago, Retro Rich said: Little bit in the expansion bottle won’t hurt 😉 Certainly not mate, but once it becomes the majority fluid that's when the niggles start and the UK version is not long life either 🙄 12 hours ago, KingK0ng said: What do you use now ? Preston coolant concentrate 35% mix works well, allot of older Hondas specified 35% anyway, rather than type 2 50/50 mix 3 Link to comment Share on other sites More sharing options...
rich1068 Posted April 19, 2021 Report Share Posted April 19, 2021 Hello knowledgeable types, Is there a coolant change how-to on here somewhere? Took the expansion tank out to get at the bulbs and couldn't help noticing that it appeared to be largely water. 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 19, 2021 Author Administrators Report Share Posted April 19, 2021 45 minutes ago, rich1068 said: Is there a coolant change how-to on here somewhere? A couple of pictures illustrating the bottom radiator drain, worth checking out the topic link below, its basically the same process on the coupe. 2 1 Link to comment Share on other sites More sharing options...
rich1068 Posted April 19, 2021 Report Share Posted April 19, 2021 Excellent. Cheers. 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 19, 2021 Author Administrators Report Share Posted April 19, 2021 On 4/19/2021 at 3:14 PM, rich1068 said: Excellent. Cheers. I have just updated the topic with more pictures and detailed text, hope it helps m8y 👍 2 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 19, 2021 Moderators Report Share Posted April 19, 2021 3 hours ago, rich1068 said: Hello knowledgeable types, Is there a coolant change how-to on here somewhere? Took the expansion tank out to get at the bulbs and couldn't help noticing that it appeared to be largely water. Oh and another thing to check whilst you are under there, another pearl of wisdom from Stu. 😃 1 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 19, 2021 Author Administrators Report Share Posted April 19, 2021 6 hours ago, PTR200S said: Oh and another thing to check whilst you are under there, another pearl of wisdom from Stu. 😃 Thanks for the important reminder Pete 😉👍 2 Link to comment Share on other sites More sharing options...
Andy Mc Posted February 26, 2023 Report Share Posted February 26, 2023 Is there a coolant drain plug on the coupe and a bleed valve like on the Eric car guy video? Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 26, 2023 Author Administrators Report Share Posted February 26, 2023 25 minutes ago, Andy Mc said: Is there a coolant drain plug on the coupe and a bleed valve like on the Eric car guy video? Yes, it is pictured on this topic ⬆️ have a scroll up the posts. 👍 2 Link to comment Share on other sites More sharing options...
Andy Mc Posted February 27, 2023 Report Share Posted February 27, 2023 Cheers. Was just double checking it wasn't on other models like the oddy etc 👍 2 Link to comment Share on other sites More sharing options...
Andy Mc Posted February 27, 2023 Report Share Posted February 27, 2023 No bleed valve found 🤔 but manky fluid swapped out for Prestone and the lower pipe clamp replaced too, which only had one of the thin parts still connected. Rest came off in my hand! Ran up to temperature then for a razz. V.quick car 😃 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 28, 2023 Author Administrators Report Share Posted February 28, 2023 On 2/27/2023 at 9:53 PM, Andy Mc said: manky fluid swapped out for Prestone and the lower pipe clamp replaced too Good Man 👍 2 Link to comment Share on other sites More sharing options...
Andy Mc Posted March 1, 2023 Report Share Posted March 1, 2023 Maybe a bump needed for the clamp warning. Depending on the viewing angle it may be deceptive if you can only see the thick side, when it's the two thin sections which are the real weak point to check. New phone keeps glitching with this forum and throw multiple spaces and new lines when typing 🙄 not sure why but takes ages to correct. Also lost drop box links for images. Will drop one in Whatssapp 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 1, 2023 Author Administrators Report Share Posted March 1, 2023 2 hours ago, Andy Mc said: Maybe a bump needed for the clamp warning. 3 Link to comment Share on other sites More sharing options...
