Site Subscriber’s RevvinKevin Posted July 26, 2023 Site Subscriber’s Report Share Posted July 26, 2023 About a week ago, jumped in my KB1 Legend, 1st thing, started it and hit the rear window/mirrors heater switch, immediately interfering with the FM station(s). Sounds like REALLY bad static noise. Never happened before in my 2 years of ownership. It's not an isolated case either as it happens every time and the FM is impossible to listen to when the heater switch is on. Any ideas where I should be looking for the cause? The switch? Heater/aerial connections? I have no issues with FM otherwise. Will check AM and LW tomorrow 1 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted July 26, 2023 Moderators Report Share Posted July 26, 2023 Sounds like the aerial amp to me, on the KA1 and Rover 800 this was centrally mounted on the underside of the rear parcel shelf, daresay it's in the same position (or near) on the KB1 as it supplies power to the HRW and also uses the HRW element as the aerial. Chances are there's a dry solder joint inside the amp unit. 1 Link to comment Share on other sites More sharing options...
Site Subscriber’s RevvinKevin Posted July 27, 2023 Author Site Subscriber’s Report Share Posted July 27, 2023 I'll have a look. Sounds reasonable as the car was sat in the full heat of this summers sun for a few days straight, unused. 2 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted July 27, 2023 Founding Member Report Share Posted July 27, 2023 It seems it's a common issue for Legends or RLs. https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/05rl-fm-radio-static-rear-defrost-802927/ 2 Link to comment Share on other sites More sharing options...
Site Subscriber’s RevvinKevin Posted August 4, 2023 Author Site Subscriber’s Report Share Posted August 4, 2023 So, in the C pillar rather than the rear parcel shelf. Thanks for the link 2 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted August 5, 2023 Founding Member Report Share Posted August 5, 2023 There is always the AliExpress Android option if you cant get the System working. https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/navitech-android-auto-w-full-android-system-1001817/ https://www.aliexpress.com/item/1005003567982750.html Let me know how it works 😁 Link to comment Share on other sites More sharing options...
