Harry93 Posted May 15, 2023 Report Share Posted May 15, 2023 Does anyone know how to remove the rear seat backs from its hinges? Looking to do a thorough leather clean and prefer taking the seats out, especially the back ones as there is little space. Also any suggestions on how to remove the front driver seat before disconnecting the battery? I know there is a connection somewhere underneath that needs to be disconnected but is it best to move the seat towards the rear and tilt upwards to gain access to the front and rear rail bolts? 2 Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted May 22, 2023 Founding Member Report Share Posted May 22, 2023 On 5/15/2023 at 2:01 PM, Harry93 said: Does anyone know how to remove the rear seat backs from its hinges? Hello mate, from memory there is a 10mm-14mm bolt in the gap between rear back seat and bottom rear seat. You’ll need an extension on a ratchet and it’s a bit fiddly. After undoing this grab the front of the bottom seat (where is meets the carpet) and pull up as there are a couple of clips (made of either metal or a strong plastic) that are imbedded in metal floor on which the seat sits. On 5/15/2023 at 2:01 PM, Harry93 said: Also any suggestions on how to remove the front driver seat before disconnecting the battery? You’re right mate, undo the 4 bolts under the seat. You might have to move the seat forwards and backwards to get them. I also put the back of the seat forward as it is easier to take the seat out of the car. I unplug the seat at the end. 2 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 22, 2023 Moderators Report Share Posted May 22, 2023 Excellent information AhsyV6, 👏👏👏 My seat came out easily when I was adding sound insulation a while back. 2 Link to comment Share on other sites More sharing options...
Harry93 Posted May 22, 2023 Author Report Share Posted May 22, 2023 Thankyou Ashy. Was waiting on some helpful advice 👍. I haven't done it yet, but hopefully if I get time, maybe during this weekend. 4 Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted May 22, 2023 Founding Member Report Share Posted May 22, 2023 10 hours ago, PTR200S said: Excellent information AhsyV6, 👏👏👏 My seat came out easily when I was adding sound insulation a while back. I bet that insulation made a hell of a difference in our noisy coupe? 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted May 22, 2023 Administrators Report Share Posted May 22, 2023 Thanks for sharing the info @AhsyV6 👍 1 Link to comment Share on other sites More sharing options...
