Bijomaru Posted August 13, 2020 Report Share Posted August 13, 2020 Does anyone have the correct parameters for setting up tracking in a 3.5 Elysion Prestige? Mine's pulling to the left after new tyres were fitted. First garage gave up as their system has not details for that car. ATS is doing really well in that they researched and can adjust it so that it's 'better' but without the parameters can't get it done exactly right. 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted August 13, 2020 Moderators Report Share Posted August 13, 2020 Only figures I have seen has been 0 degrees on front, parallel if you like. Rear are toe in 0.01...... I will see if my mot mate can help, they have full track and alignment gear... Too late now but will check tomorrow 3 Link to comment Share on other sites More sharing options...
Bijomaru Posted August 13, 2020 Author Report Share Posted August 13, 2020 Even if I can’t let them know before we go for our trip, they’ve offered to do a free alignment once I have the parameters, so if you can share those it would still be great. Should I assume that most people here have their alignment done ‘as good as it can be’ without the garages having the proper specifications? It can’t be that Swindon is so far behind that big names don’t have those at hand 🤣 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted August 14, 2020 Moderators Report Share Posted August 14, 2020 not good news on the alignment, no figures but I am sure I have seen someone getting it done with a company.?..ATS maybe...just have to keep asking around. Added to list of things we need to know on the Elysion 🤔 1 Link to comment Share on other sites More sharing options...
Founding Member Brett Posted August 15, 2020 Founding Member Report Share Posted August 15, 2020 The best alignment machine is a hunter but if you have all the perimeters even better. I always used the hunter on my 8th gen and was always spot on. 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted August 15, 2020 Moderators Report Share Posted August 15, 2020 On 8/13/2020 at 6:35 PM, PTR200S said: Only figures I have seen has been 0 degrees on front, parallel if you like. Rear are toe in 0.01...... I will see if my mot mate can help, they have full track and alignment gear... Too late now but will check tomorrow Most of the Hondas seem to be parallel (0deg toe) on the front and the rear seems to vary. For example the rear on my Rover is (from memory without checking) something like 0.5-1.0mm toe in which is about 0deg 22' or roughly 1/3 of a degree +/- 0deg 15'. Not sure what the Accord Coupe is, if Stu could perhaps furnish those figures we might see a pattern emerging and perhaps the Odyssey as well. Then make a "best guess" which i'd suggest would be somewhere close to these figures. 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted August 15, 2020 Moderators Report Share Posted August 15, 2020 2 hours ago, Laird_Scooby said: perhaps the Odyssey as well. this might be the best bet if we don't come up with some definitive figures.... 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted August 15, 2020 Moderators Report Share Posted August 15, 2020 2 hours ago, Brett said: The best alignment machine is a hunter but if you have all the perimeters even better. I always used the hunter on my 8th gen and was always spot on. Yep, my mot man has the hunter but without the parameter information its not much use...what he can do is have a look at what mine is set to at the moment...BUT....cracked a double pothole yesterday and it is pulling to the left 😭 1 Link to comment Share on other sites More sharing options...
