TANNERS Posted July 15, 2020 Report Share Posted July 15, 2020 Had a little look. But can't figure out how the number plate light covers come off?? 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted July 16, 2020 Moderators Report Share Posted July 16, 2020 Is that to replace bulbs? If I recall its access is in the inspection plate on the inside of the hatch, in centre...... 1 Link to comment Share on other sites More sharing options...
st123 Posted July 16, 2020 Report Share Posted July 16, 2020 But if you have fat fingers like me you have to take the inner boot cover off😁 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted July 16, 2020 Moderators Report Share Posted July 16, 2020 12 minutes ago, st123 said: But if you have fat fingers like me you have to take the inner boot cover off😁 Its possible to unclip the bulb unit from the back but if you use the access cover you can see the clips on the unit, one is rounded the other flat. Go for the rounded one and lever that side off from the outside.... carefully!!! They are fragile, best done in warm weather, sunshine on the rear of the van !! Once you have broken one side the other will come out easily 😄 Number 14 !! about 4 quid plus carriage !! 2 Link to comment Share on other sites More sharing options...
TANNERS Posted July 17, 2020 Author Report Share Posted July 17, 2020 🤣😂🤣😂🤣👍👍👍👍 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted July 17, 2020 Moderators Report Share Posted July 17, 2020 Are you in the rear end ?? 🤪 with your bulbs hanging out, now?? 😁 3 Link to comment Share on other sites More sharing options...
TANNERS Posted July 17, 2020 Author Report Share Posted July 17, 2020 Ooo matron 4 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 22, 2022 Moderators Report Share Posted May 22, 2022 Offside number plate light out....easy , peasy .....ok, perhaps not !! The outer cover wouldn't release this time so got swmbo to insert hand through the internal rear inspection cover and around the cables for the latch mech. The wiring plug came out and then the bulb holder no problem....I changed bulb and swmbo inserts it back through the hole...and drops it 😱😱😱 into the panel inside the hatch. Needs a Tanner touch now!!! Out with the nylon trim removers, unscrew the pull down tailgate handle and remove the BIG tailgate trim !! 5 minutes, all done.... I don't know why I bothered with the rear entry hatch, .....😜😜 just get the cover off and get on with it !!!!! Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted May 22, 2022 Founding Member Report Share Posted May 22, 2022 I reckon that those who never have trouble doing these supposedly simple jobs never actually do the job themselves.... or they are experts! 1 Link to comment Share on other sites More sharing options...
