Gyula Posted April 11, 2020 Report Share Posted April 11, 2020 Hi all! I have a cg4 2.0 accord coupe, and the passenger window regulator is need to be changed as it doesn't close properly. I have found one, which is from the same year, but from a cg2 3.0 accord coupe. My question is, is there any difference in between these parts or not? And over all is what is the difference in between cg2 and cg4 Thank you very much for all your help guys! 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 11, 2020 Administrators Report Share Posted April 11, 2020 First off welcome to the club and secondly, the 3.0 V6 window regulator is interchangeable, so grab it. Thirdly apart from the obvious differences in the engine compartment, the fuel system i.e sender (fuel tank the same) and instrument cluster, rear calipers, rear subframe, exhaust, lambda sensors are not interchangeable, everything else will interchange but the car won't feel right on CG2 OEM front coil springs or vice versa. Think that's it, may have forgotten something 🙃 2 1 Link to comment Share on other sites More sharing options...
Gyula Posted April 12, 2020 Author Report Share Posted April 12, 2020 First of all thank you to be here, I'm sure I will have a lot of questions in the future And thank you very much for your help as well!!! 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 12, 2020 Administrators Report Share Posted April 12, 2020 No problem we are always happy to help, 😉 please feel free to share some pictures of your motor in the gallery: https://honda6.ipbhost.com/forum/247-gallery/ 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 13, 2020 Moderators Report Share Posted April 13, 2020 Welcome to you, from me, as well! Please do ask questions, someone here will almost certainly be able to help and don't forget those pictures / bit about yourself ! 🙂 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 13, 2020 Moderators Report Share Posted April 13, 2020 Welcome aboard! 2 Link to comment Share on other sites More sharing options...
