Founding Member PaulS Posted June 22, 2019 Founding Member Report Share Posted June 22, 2019 Seems my rear number plate lamp mountings have rusted through as one is now hanging loose over the number plate. So I need to sort this out - but first I have to remove the rear platic bumper. I see the plastic pop clips but are there any hidden clips / bolts / screws - or indeed any list of things tpo remove and in what order? Thanks for your help.... 1 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 23, 2019 Administrators Report Share Posted June 23, 2019 These topics might help you Paul, not sure if you're going OEM or DIY route linked my repair in the last topic either way... 2 Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted June 23, 2019 Author Founding Member Report Share Posted June 23, 2019 Thanks Stu. Just spent 3 hours getting the rusty brackets off. Screws were rusted solid and would not drill out either so I ground the heads off with a small carbide burr. So I got the lamp holders out but had no idea what the brackets looked like! Think I will make some out of a bit of UPVC strip I have so they will never rust again! To save taking the whole rear bumper off, does the small panel around the number plate actually come out from the bumper? If so it will make replacing the lamps quite simple. I can find 2 clips which will allow the RH side to come loose but although the 2 LH side clips can be unhooked, something else which I cannot see stops it coming out. 2 Link to comment Share on other sites More sharing options...
Site Subscriber’s Chrismas Posted June 24, 2019 Site Subscriber’s Report Share Posted June 24, 2019 19 hours ago, PaulS said: Thanks Stu. Just spent 3 hours getting the rusty brackets off. Screws were rusted solid and would not drill out either so I ground the heads off with a small carbide burr. So I got the lamp holders out but had no idea what the brackets looked like! Think I will make some out of a bit of UPVC strip I have so they will never rust again! To save taking the whole rear bumper off, does the small panel around the number plate actually come out from the bumper? If so it will make replacing the lamps quite simple. I can find 2 clips which will allow the RH side to come loose but although the 2 LH side clips can be unhooked, something else which I cannot see stops it coming out. Just read this old post, and it looks like I have no diffuser /light cover for my number light, although the bracket holding the bulbs is still there. Are these obtainable? Stu, can you let me know where you get your spares from in the USA? 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 24, 2019 Administrators Report Share Posted June 24, 2019 1 hour ago, Chrismas said: looks like I have no diffuser /light cover for my number light, although the bracket holding the bulbs is still there There's no cover where the lights are fitted apart from the bowl shape lenses covering them, they're all open on the coupe... 21 hours ago, PaulS said: oes the small panel around the number plate actually come out from the bumper? Yes, it does come off Paul its held on with a plastic frame & screws which only really accessible if you take the bumper off. 2 1 Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted June 24, 2019 Author Founding Member Report Share Posted June 24, 2019 OK thanks., I have now sorted it. Quite easy once one gets one's head around it. 2 pieces of 2" plastic trunking around 5 inches long, 8 alloy rivet nuts and 8 stainless steel allen bolts and a bit of silicone grease, all fixed from outside as the bracket space was accessible without removing the bumper! 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted June 24, 2019 Administrators Report Share Posted June 24, 2019 1 hour ago, PaulS said: OK thanks., I have now sorted it. Quite easy once one gets one's head around it. 2 pieces of 2" plastic trunking around 5 inches long, 8 alloy rivet nuts and 8 stainless steel allen bolts and a bit of silicone grease, all fixed from outside as the bracket space was accessible without removing the bumper! Great work and any pictures to add to the existing topic on this would be mucho appreciated Paul 👍 2 Link to comment Share on other sites More sharing options...
