Moderators PTR200S Posted May 1, 2019 Moderators Report Share Posted May 1, 2019 Needed to fold the mirrors in on the Coupe today.... Erm, stuck !!! I know mirrors usually need a firm push but these seem to be almost bending the brackets out. Surely both can't have seized? Or is there a secret control somewhere !!!.😅 I have never folded them in before, since i got it in fact. And nobody else has tried to fold them in by passing to closely ! 1 1 Link to comment Share on other sites More sharing options...
KingK0ng Posted May 1, 2019 Report Share Posted May 1, 2019 Your mirrors still seems virgin 😆 I do fold mine regulary to enter to my garage, our coupe need indeed a very firm push. Try again while holding the bracket with one hand and with the other make some multiple first slight push and further increase force, i guess it should pop and come in at some point. 2 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted May 1, 2019 Administrators Report Share Posted May 1, 2019 You won't be the first to think they are stuck, quick video for you Pete, just lift a little and push... 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 1, 2019 Author Moderators Report Share Posted May 1, 2019 Will give it a go again tomorrow, .....did try lifting actually but as the video shows it needs quite a lift, you can hear the strain as its lifted !!! Sprayed them with lube tonight so if they are "stuck" that should help . Will report back, as they say !! Thanks Stu. 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted May 1, 2019 Administrators Report Share Posted May 1, 2019 That mirror hadn't been folded in for a few years, the ones on my coupe are easy to fold in 👍 1 1 Link to comment Share on other sites More sharing options...
welland99 Posted May 2, 2019 Report Share Posted May 2, 2019 I have never folder mine in over 10 years, but did recently have a go. Like Pete, I thought they must be stuck, so gave up. Thanks for the video, Stu, I'll have another go sometime. 2 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 2, 2019 Author Moderators Report Share Posted May 2, 2019 Good news, they move, albeit stiffly. ! More lube and cleaning needed, the crud under the hinge area looks like a dried up swamp ! I think the one and only previous owner never moved them and i certainly haven't ! They don't seem to move upwards, more on a turn in / up ramp basis.....there is no clearance to physically lift initially, only as they move inwards, could be crud or maybe mirrors are different on later cars....anyway more work needed to get them sorted properly. 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 2, 2019 Author Moderators Report Share Posted May 2, 2019 4 hours ago, welland99 said: I have never folder mine in over 10 years, but did recently have a go. Like Pete, I thought they must be stuck, so gave up. Thanks for the video, Stu, I'll have another go sometime. Squirting some form of lube in the hinge area certainly started the process off for me as they were threatening to tear the holding bracket off when I tried to move them initially. 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 2, 2019 Author Moderators Report Share Posted May 2, 2019 Got them moving relatively easily now, more lube up the back passage definitely helps 😉 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted May 3, 2019 Moderators Report Share Posted May 3, 2019 15 hours ago, PTR200S said: lube up the back passage definitely helps Ooooooo-errrrrr missus! I wonder how many owners don't actually know they fold in, never mind tried? 🤔 1 Link to comment Share on other sites More sharing options...
