st123 Posted August 4, 2020 Report Share Posted August 4, 2020 https://www.amayama.com/en have both parts available 77265-SJK-J01ZA 77160-SJK-J01ZZ 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted August 4, 2020 Author Moderators Report Share Posted August 4, 2020 Thanks for that, if they have stock then worth ordering, getting the sat nav after the surround arrives , just in case. 🙄 4 Link to comment Share on other sites More sharing options...
dmac NZ Posted March 11, 2021 Report Share Posted March 11, 2021 Hello. Did you need a special wiring harness or anything? Did the generic 2 DIN Android stereo just come with all of the wiring and other bits and pieces needed to connect it to the built-in audio? Do you still hear the Japanese voice prompts, etc. or is that generated from the factory head unit? Does your vehicle have composite/RCA connectors in the back so you can connect old video players and/or a screen mounted to the ceiling? If so, does that still work? 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 12, 2021 Author Moderators Report Share Posted March 12, 2021 On 3/11/2021 at 9:22 AM, dmac NZ said: Hello. Did you need a special wiring harness or anything? Did the generic 2 DIN Android stereo just come with all of the wiring and other bits and pieces needed to connect it to the built-in audio? Do you still hear the Japanese voice prompts, etc. or is that generated from the factory head unit? Does your vehicle have composite/RCA connectors in the back so you can connect old video players and/or a screen mounted to the ceiling? If so, does that still work? Hi and welcome to H6nda 😁 Don't forget to introduce yourself and your Elysion on the Newbie section.😃 To try and answer your questions, each radio install is different but generally you will have a radio plug supplied with the unit which you will need to cobble to the existing wiring. This will eliminate all dashboard controls...everything can be done off the new install touchscreen or remote There are no jap voice prompts as the total system is disconnected and was part of the head unit. I don't have a rear mount video unit so can't help there. There are rear connections for various things but as I sit in the front seat I have never bothered with it.🤪 There is a Russian website offering complete conversion kits but as for install you are on your own again . I believe that the Odyssey head unit can be used as a direct replacement but I have never seen any details but likely a try it and see regarding connections. 1 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted March 12, 2021 Moderators Report Share Posted March 12, 2021 Welcome aboard from me as well. Would be worth checking out the autoleads website to see what parts are available including interfaces for existing steering wheel controls to new head units - you need to know what sort of controls the steering wheel has though. If they are resistive, you're pretty much sorted, if they're CANBus it's a bit of a shit shot in the dark as to whether you can get the right interface or not. 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 13, 2021 Administrators Report Share Posted March 13, 2021 On 3/11/2021 at 9:22 AM, dmac NZ said: Hello. Welcome to the club 🖐️ 2 Link to comment Share on other sites More sharing options...
manuellbills Posted August 10, 2021 Report Share Posted August 10, 2021 On 2/7/2019 at 5:15 PM, PTR200S said: The part numbers are apparently as follows, a search brings them up on line but as unavailable .....haven't really had a chance to go at it properly but have a search yourself by all means . 77265-SJK-J01ZA 77160-SJK-J01ZZ http://jp-carparts.com/images/honda/parts_image/11SJK501/B_37_10.png items 3 and 10, I think the no 10 item has two colours, this I believe is the beige coloured one. 1 47103-SFA-000 LABEL, FOOT PARKING JPY 168 USD 1.61 2 66418-579-000 STOPPER, GLOVE BOX LID JPY 278 USD 2.65 3 77160-SJK-J01ZZ FRAME COMP., INSTRUMENT CENTER (RH) JPY 4,512 USD 42.97 4 77200-SJK-J01ZA VISOR ASSY., METER LOWER *NH167L* JPY 10,182 USD 96.97 4 77200-SJK-003ZA VISOR ASSY., METER LOWER *NH167L* JPY 10,182 USD 96.97 5 77205-SJK-003ZA GARNISH ASSY., METER UPPER *NH557L* JPY 6,915 USD 65.86 5 77205-SJK-003ZB GARNISH ASSY., METER UPPER *YR291L* JPY 6,915 USD 65.86 6 77205-S0X-A01 CLIP. SNAP FITTING JPY 125 USD 1.19 7 77220-SJK-003ZA GARNISH ASSY.,R. METER *NH558L* JPY 5,523 USD 52.60 8 77225-SJK-003ZA GARNISH ASSY.,L. METER *NH558L* JPY 5,523 USD 52.60 9 77240-S7S-000 LID ASSY., AUDIO WOLE JPY 645 USD 6.14 10 77265-SJK-J01ZA PANEL ASSY., DISPLAY *NH557L* JPY 18,020 USD 171.61 10 77265-SJK-J01ZB PANEL ASSY., DISPLAY *YR291L* JPY 18,020 USD 171.61 Not a great pic but shows you what it looks like compared to the diagram above. Will try and take a better picture when I get a chance. Hi, I am trying to source these parts. I am not able to get hold of the plastic cover. Any advise or guidance. 4 Link to comment Share on other sites More sharing options...
st123 Posted August 10, 2021 Report Share Posted August 10, 2021 77265SJKJ02ZA is on amayama for £132 inc postage 2 Link to comment Share on other sites More sharing options...
manuellbills Posted August 10, 2021 Report Share Posted August 10, 2021 55 minutes ago, st123 said: 77265SJKJ02ZA is on amayama for £132 inc postage Thanks a ton mate. I did not know about 77265SJKJ02ZA . jumping with joy now. Fingers crossed. It is Obon Holidays in Japan. 3 Link to comment Share on other sites More sharing options...
manuellbills Posted August 25, 2021 Report Share Posted August 25, 2021 On 8/10/2021 at 2:40 PM, manuellbills said: Thanks a ton mate. I did not know about 77265SJKJ02ZA . jumping with joy now. Fingers crossed. It is Obon Holidays in Japan. Hello Folks, Absolutely heart broken yesterday. Amayama has cancelled my order stating 77265-SJK-J02ZA is out of stock. Not sure what to do. I have asked my f @PTR200S @st123 AND OTHERS - Any advise or help here please. Thank you 2 Link to comment Share on other sites More sharing options...
manuellbills Posted September 13, 2021 Report Share Posted September 13, 2021 Just a quick update folks, the parts arrived today from Japan (Amayama) . There was one in stock finally . 🕺. Dancing with joy. Will keep you all updated when I have fitted the Double DIN. Will probably post a facebook link as I don't have the permissions here to add images. Cheers 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted September 13, 2021 Author Moderators Report Share Posted September 13, 2021 Excellent news !! Have you got all the bits you need now? Did you have to keep looking at the amayama site ,or did they come back to you, to order? 1 Link to comment Share on other sites More sharing options...
manuellbills Posted September 13, 2021 Report Share Posted September 13, 2021 I bought this part - 77265-SJK-J02ZB Did lot of browsing the internet and ended up with this part reference. 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted September 13, 2021 Author Moderators Report Share Posted September 13, 2021 1 hour ago, manuellbills said: I bought this part - 77265-SJK-J02ZB Did lot of browsing the internet and ended up with this part reference. That's the same reference then but different suffix ?? Colour possibly? Beige 🤣 1 Link to comment Share on other sites More sharing options...
CarlitoE1 Posted March 24, 2022 Report Share Posted March 24, 2022 Hi just signed up to ask for your help my dad has just brought a 2008 honda elysion prestige 3.5 v6 in pearl white. awesome car very much let down by the stereo and nav. So stupidly I talked him into trying a Chinese android unit as it was supposed to be plug and play! What a mistake that was. So queue lots of Google searches and I have managed to get 90% of the way there it turns on and you can hear it but I was really hoping to get steering wheel controls working. Are they resistance based on this model or is it canbus? How do you tell the difference? Also I'm needing the reverse switch for the reverse camera I'm running a new camera and lead for that so I just need the reverse switch cable. I have so far removed so many modules for tvs no longer present and I'm guessing Toll modules soo many things removed. So hoping someone can help me just get the last few bits sorted and it's a success. Cheers Carl Link to comment Share on other sites More sharing options...
KingK0ng Posted March 24, 2022 Report Share Posted March 24, 2022 56 minutes ago, CarlitoE1 said: Hi just signed up to ask for your help my dad has just brought a 2008 honda elysion prestige 3.5 v6 in pearl white. awesome car very much let down by the stereo and nav. So stupidly I talked him into trying a Chinese android unit as it was supposed to be plug and play! What a mistake that was. So queue lots of Google searches and I have managed to get 90% of the way there it turns on and you can hear it but I was really hoping to get steering wheel controls working. Are they resistance based on this model or is it canbus? How do you tell the difference? Also I'm needing the reverse switch for the reverse camera I'm running a new camera and lead for that so I just need the reverse switch cable. I have so far removed so many modules for tvs no longer present and I'm guessing Toll modules soo many things removed. So hoping someone can help me just get the last few bits sorted and it's a success. Cheers Carl For the steering wheel controls it's usually the wires KEY 1 and KEY 2. For the reverse camera to engage you need to source it directly to the reverse tail light. 1 1 Link to comment Share on other sites More sharing options...
CarlitoE1 Posted March 25, 2022 Report Share Posted March 25, 2022 Hi thanks for the reply I see so which wires do I need for key1 and key2? Ahh that makes sense for the reverse camera I wasn't sure if it needed a switch ground or feed from the gear selector. Link to comment Share on other sites More sharing options...
Dylan42 Posted June 28, 2023 Report Share Posted June 28, 2023 I have been researching for weeks on this install and I am grateful for some of the info here. Most the Japanese translated sites I find tell me I need to pull speaker wires from my factory amp to make this install work. Does anyone know where I can find wiring diagrams? OP did you just splice into the existing harness that was from the OEM display? If so what wires did you connect? Thanks. 1 Link to comment Share on other sites More sharing options...
Daniel Law Posted February 13 Report Share Posted February 13 I have a brand new Head unit in box that came with the vehicle. It says D-3 Elysion (12-15) on a sticker on the unit. My vehicle is an 08 plate so I doubt this will fit or do you buy a larger plastic nav screen trim? 1 Link to comment Share on other sites More sharing options...
