Moderators PTR200S Posted May 16, 2021 Author Moderators Report Share Posted May 16, 2021 If it is the battery I will be severely annoyed...New battery last year and I kept up on periodic charging. 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted May 16, 2021 Moderators Report Share Posted May 16, 2021 4 minutes ago, PTR200S said: If it is the battery I will be severely annoyed...New battery last year and I kept up on periodic charging. Despite your efforts Pete, during the cold weather you need to be lucky every night, even with a relatively new battery. The cold only needs to be "lucky" once to kill your battery. 1 Link to comment Share on other sites More sharing options...
Founding Member PaulS Posted May 16, 2021 Founding Member Report Share Posted May 16, 2021 Easy to check battery volts to see if it is that - simply open the bonnet and put voltmeter across before starting the car... Do the same thing when you park up for the night and see what - if any - difference there is between night and morning.... 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted May 16, 2021 Moderators Report Share Posted May 16, 2021 That's only half the test though, really need to see if the battery is taking all the charge it should. These days most batteries are sealed for life so it's difficult to use a hydrometer to check each cell strength - easiest test would be by substitution of a known good battery. 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted May 18, 2021 Author Moderators Report Share Posted May 18, 2021 Second hand unit arrived today, came with the centre console still attached 😃 Haven't been out in Coupe since Sunday so no idea yet if OK from the "repair" , just hope the s/h unit OK if I have to change over. 1 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted May 18, 2021 Moderators Report Share Posted May 18, 2021 Hopefully you've got all bases covered now Pete! If the "repair" doesn't appear to have worked and you fit this one and it displays the same problem, i'd look towards the battery but see if the existing one comes to life by itself after a few minutes running untouched like i suggested before. 2 Link to comment Share on other sites More sharing options...
