Administrators hughezee Posted January 25, 2018 Administrators Report Share Posted January 25, 2018 As a follow up to past discussions regarding engine oil and the problems with Honda 0W20 p/n: 08232P99K4LHE when used in older engines, which results in oil leaks, high oil consumption and excessive valve train wear and engine noise. So I have illustrated a few of the most common oils used by myself or recommended by other members, so if you are looking for just a standard oil I would recommend Mobil 1 ESP 0W40 or Castrol Edge 0W40 (not GTX or Magnatec). Owners looking for improved fuel economy and performance I would strongly recommend Motul 8100 X-Max 0W-40 Fully Synthetic.👍 PLEASE NOTE: the information within this topic has been kindly contributed by one of our experienced members and has been extensively researched and found to be correct by independent testing or external resources. Regards SITE DEVELOPMENT. 1 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted February 19, 2018 Founding Member Report Share Posted February 19, 2018 Lennie will be having most of his fluids replaced tomorrow and he’s looking forward to his spa day at Honda HQ. Yes he does talk to me...it might have been in German previously but he’s now speaking English. ill be taking pics at various strategic points along the way and post them up tomorrow. Off to bed. Beep Beep. Hondaaaaaaaaaaaaaa 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 20, 2018 Author Administrators Report Share Posted February 20, 2018 Quick shot of Lennie in a very cooperative mood enjoying his spa day, now running smoother and more economical than ever. 2 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted February 20, 2018 Founding Member Report Share Posted February 20, 2018 Lennie Legend had a great day at Stu’s, he certainly runs a bit quieter and Stu said the MPG should increase a bit and the emissions should reduce too, so happy days. The main priority now the essential fluids are done is the rear differential fluid change and Lennie will be one happy Legend. As always, many thanks to Stu for his expertise. 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 20, 2018 Author Administrators Report Share Posted February 20, 2018 Had a great day mate, enjoyed the McMuffin & pasty (fake) and Red Bull, thank You 3 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted February 20, 2018 Founding Member Report Share Posted February 20, 2018 And I thought Ginsters were the real deal. Pleasure as always Stu, can’t go wrong with a Red Bull and a fake pasty. Man Food. 2 Link to comment Share on other sites More sharing options...
Founding Member Brett Posted February 20, 2018 Founding Member Report Share Posted February 20, 2018 Always liked the Mobil ESP oil, assuming that's what Stu put in? 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 20, 2018 Author Administrators Report Share Posted February 20, 2018 On 2/20/2018 at 6:31 PM, Brett said: assuming that's what Stu put in? Not telling. 😆 2 1 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted February 20, 2018 Founding Member Report Share Posted February 20, 2018 2 Link to comment Share on other sites More sharing options...
Site Subscriber’s RevvinKevin Posted March 11, 2021 Site Subscriber’s Report Share Posted March 11, 2021 Can't see anything on oil filters for the KB1. Do you have a Honda part no. Or a highly recommended alternative please? 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 12, 2021 Moderators Report Share Posted March 12, 2021 Think the original honda part number is 15400 RBA F01 Honda changed a lot of individual filter numbers for just a couple of filters to suit cars across their ranges, they did the same with motorcycles too. Stu should be able to confirm the correct one but if the S2000 filter, bigger of the two available will fit, i would go for that . 15400 PCX 004 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 12, 2021 Author Administrators Report Share Posted March 12, 2021 10 hours ago, RevvinKevin said: Can't see anything on oil filters for the KB1. Do you have a Honda part no. I would suggest just get the standard Honda filter: 15400RBAF01 for the KB1 or the Blueprint ADH22114, the 15400 PCX 004 filter is a great suggestion from Pete, but given the location of the filter, it could foul the sump pan. I would just get a filter from cox's and you get a new sump washer too: https://www.coxmotorparts.co.uk/honda-shop/genuine-honda-legend-oil-filter-sump-washer/ Hope that helps fella 👍 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 12, 2021 Moderators Report Share Posted March 12, 2021 7 hours ago, hughezee said: but given the location of the filter, it could foul the sump pan. I would just get a filter from cox's and you get a new sump washer too: https://www.coxmotorparts.co.uk/honda-shop/genuine-honda-legend-oil-filter-sump-washer/ Hope that helps fella 👍 That's what I wondered too, the amount of space/clearance, as you say . The standard filter is quite a bit narrower so a good call. 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 12, 2021 Author Administrators Report Share Posted March 12, 2021 12 minutes ago, PTR200S said: That's what I wondered too Yeah, the filter is not positioned like the V6 Accord or the earlier V6 Elysion, although I will double-check with 15400 PCX 004 when Geoff pops over.👍 1 1 Link to comment Share on other sites More sharing options...
