welland99 Posted February 13, 2018 Report Share Posted February 13, 2018 I bought this obd2 diagnostic adapter for my SMAX last year, but I no longer have the smax: http://www.smaxownersclub.com/forum/showthread.php?10294-SMOC-Modified-ELM327-S-Max-Diagnostic-Tool&highlight=Elm327 (Don't know if that link will work for non-SMAXOC-members) Would this be any use for my cg4? What software would I need on my pc? Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 13, 2018 Administrators Report Share Posted February 13, 2018 The 1998-2002 Accord coupe only moved to the standard OBD2 16 pin/plug socket, in late 2001 models with the F20B7 engine, so yours being an F20B5 engine will have the three pin connector and probably won't work on the protocols loaded on the scanner even with an adaptor cable? 1 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted February 13, 2018 Founding Member Report Share Posted February 13, 2018 ^^^^ what Stu said. 2 Link to comment Share on other sites More sharing options...
welland99 Posted February 13, 2018 Author Report Share Posted February 13, 2018 That's a shame. Before I read your replies, I already did a bit of googling and found this site: https://www.outilsobdfacile.com/vehicle-list-compatible-obd2/honda I thought it was saying that there would be an OBD2 port on the CG4, but it can't be (or I was reading it wrong). So, is the following correct: OBD = 3 pin? OBD2 = 16 pin? 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 13, 2018 Administrators Report Share Posted February 13, 2018 26 minutes ago, welland99 said: So, is the following correct: OBD = 3 pin? OBD2 = 16 pin? Basically yes, the info on that site refers to the European model, the early 1.8L UK built Accord also has a three pin plug until late 2000. 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 14, 2018 Moderators Report Share Posted February 14, 2018 10 hours ago, hughezee said: The 1998-2002 Accord coupe only moved to the standard OBD2 16 pin/plug socket, in late 2001 models with the F20B7 engine, so yours being an F20B5 engine will have the three pin connector and probably won't work on the protocols loaded on the scanner even with an adaptor cable? Stu, do you have any engine / vin numbers ranges for OBD2 series? Just wondering about mine. As far as three pin connectors go I presume one connection is an earth or return feed... Just wondering if the Roverguage system could be useful or adapted?? Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 14, 2018 Administrators Report Share Posted February 14, 2018 Late 2001-2002 coupes have the 16 pin socket only seen one 2002 coupe 3.0 with it and a couple of 2001 2.0L's, few pic's below which give a better description. 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 14, 2018 Moderators Report Share Posted February 14, 2018 Are those converter plugs easy to get or is it a Honda only kit? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 14, 2018 Administrators Report Share Posted February 14, 2018 Just now, PTR200S said: Are those converter plugs easy to get or is it a Honda only kit? Fairly easy to obtain Pete, http://www.ebay.co.uk/itm/Honda-CR-V-CRV-Diagnostic-Cable-3-Pin-Connector-Honda-Civic-CRX-Adapter-Lead/131778582545?hash=item1eae9d9811:g:bl8AAOSwv9hW3pjs 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted February 14, 2018 Moderators Report Share Posted February 14, 2018 16 minutes ago, hughezee said: Fairly easy to obtain Pete, http://www.ebay.co.uk/itm/Honda-CR-V-CRV-Diagnostic-Cable-3-Pin-Connector-Honda-Civic-CRX-Adapter-Lead/131778582545?hash=item1eae9d9811:g:bl8AAOSwv9hW3pjs Thanks for that might have to try that out presuming only a three pin plug in Coupe. I have an Icarsoft CR Plus so hopefully should be able to do something ! 2 Link to comment Share on other sites More sharing options...
