Administrators hughezee Posted November 4, 2014 Administrators Report Share Posted November 4, 2014 Well my temporary leak stop treatment worked for a while, but I think its time to fix it properly now I originally traced the leak to the oil filter housing seal and there is a little residue starting to reappear in the same location So I've ordered item: 13 p/n: 15825P8AA01 and few pic's to follow when I've sorted it Link to comment Share on other sites More sharing options...
welland99 Posted November 5, 2014 Report Share Posted November 5, 2014 Is it as awkward to change the oil filter on a v6 as it is on a 2L? 1 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted November 5, 2014 Founding Member Report Share Posted November 5, 2014 Is it as awkward to change the oil filter on a v6 as it is on a 2L? The filter is in the drivers side wheel arch on a V6, I didn't even jack my car up the last time I changed the filter, just stuck it on full lock and I could get access easily. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted November 5, 2014 Author Administrators Report Share Posted November 5, 2014 welland99 like Cryistic said it is easier to get at, here's a picture for reference Link to comment Share on other sites More sharing options...
welland99 Posted November 5, 2014 Report Share Posted November 5, 2014 The filter is in the drivers side wheel arch on a V6, I didn't even jack my car up the last time I changed the filter, just stuck it on full lock and I could get access easily. That looks handy. And being near vertical, I suppose there's little spillage. On my 2l, the filter is a real pain. On the back of the block, sideways on. Spillage is unavoidable. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted November 6, 2014 Author Administrators Report Share Posted November 6, 2014 Also forgot to mention didn't order the genuine OEM gasket from the UK and saved almost £10 in the process 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted November 15, 2014 Author Administrators Report Share Posted November 15, 2014 New gasket has arrived 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted November 15, 2014 Author Administrators Report Share Posted November 15, 2014 Remove the oil filter to drain any excess oil in the housing. Remove the three 12mm bolts and a light tap with a rubber mallet should free it The area it was leaking, the old seal was very brittle, way past it for polymers and seal conditioners Give both surfaces a good clean with clutch & brake cleaner before offering up the new seal Note: the longer of the three bolts goes in the top right hole on the housing just in case you forget New filter and carefully tighten up the bolts with your fingers with the help of a socket lock off lightly. Now in a random sequence slowly torque them up to 22 N-m (2.2 kgf-m,16 lbf-ft) No oil pressure warning light and no leaks 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 19, 2014 Author Administrators Report Share Posted December 19, 2014 After a quick inspection I can confirm the leak is resolved 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted October 1, 2018 Author Administrators Report Share Posted October 1, 2018 On 12/19/2014 at 4:30 PM, hughezee said: After a quick inspection I can confirm the leak is resolved Still, no leaks and VTEC still kicks in yo ? 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted October 1, 2018 Moderators Report Share Posted October 1, 2018 This could be where my leak is coming from, looks to be in the same place....should know come Wednesday night when the side comes off to do the timing belt 1 Link to comment Share on other sites More sharing options...
