Administrators hughezee Posted September 22, 2015 Administrators Report Share Posted September 22, 2015 Well I had a radiator leak and rather than cracking a egg white in there or using rad weld I decided to just replace it Also rather than try and disconnect every hose attached to the radiator I just removed the hoses with the best access and since I was replacing my in-line ATF filter and installing a transmission fluid cooler I removed the battery and tray. So the lower hose which connected to the thermostat housing and the cooler hoses from the gearbox lines where the easy option. but don't forget to unplug all cables and clips ect Quick test fit and eye spied the ideal location to run the ATF cooler hoses Also I decided to prime the system with transmission fluid and to see if was free flowing with no obstructions. Now once everything is re-assembled and you have topped of the coolant, also check your transmission fluid level then start the engine and check for anything might be a miss e.g leaks , all good now proceed to burp the cooling system of air... For more information on changing your coolant: http://honda6.ipbhost.com/index.php?/topic/150-honda-engine-coolant-diy-just-pictures/ For more information on transmission filters: http://honda6.ipbhost.com/index.php?/topic/74-automatic-transmission-in-line-filter-magnefine-raybestos/ For more information on transmission coolers: http://honda6.ipbhost.com/index.php?/topic/73-automatic-transmission-cooler-inline-cooler/ Feel free to ask any questions but anything relating to any of the links please ask the questions on those topics, Thanks 3 Link to comment Share on other sites More sharing options...
Founding Member Cryistic Posted September 22, 2015 Founding Member Report Share Posted September 22, 2015 Great post, which cooler did you go for in the end Stu? 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 22, 2015 Author Administrators Report Share Posted September 22, 2015 Great post, which cooler did you go for in the end Stu?I went for the ironically named TRANSAVER from Hayden, very good value 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted February 26, 2016 Author Administrators Report Share Posted February 26, 2016 Just preparing Retro Rich's new radiator + transmission cooler, so as I'm still incapacitated some what he's got the job of removing his old rad tomorrow. 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted November 3, 2017 Author Administrators Report Share Posted November 3, 2017 Quick follow up on Retro Rich's coupe, cooler still looking good and working well 3 Link to comment Share on other sites More sharing options...
Founding Member Retro Rich Posted November 7, 2017 Founding Member Report Share Posted November 7, 2017 Keeping the gear box smooth and sweet still! 3 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted November 7, 2017 Founding Member Report Share Posted November 7, 2017 Happy days Rich, how many miles do you do in a week, just curious? I only do literally 10 a day to work and back plus weekends so not racking up any mileage, mileometer has been on 109k forever! 3 Link to comment Share on other sites More sharing options...
Founding Member Retro Rich Posted November 27, 2017 Founding Member Report Share Posted November 27, 2017 Hi Geoff, I average about 250-300 miles per week, but I’m using a Honda Jazz as a daily driver now. Plan to keep the V6 in very nice condition ? That’s why I do the oil changes every 3 months or 3000 miles, whichever is sooner ? 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 21, 2019 Author Administrators Report Share Posted March 21, 2019 @MIKE_RAVEN Radiator removed and a quick shot of the new radiator with a cooler pipe appropriately sprayed in the colour heather mist and wax sealed... Still, a long way to go before fitting the radiator though, rust rectification, painting, sealing, new nuts bolts, hoses, pipes, hose clamps etc etc 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 22, 2019 Author Administrators Report Share Posted March 22, 2019 Few more pictures before the radiator goes in 🙂 All waxed and a sneaky shot of the new AC condenser going in... 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 25, 2019 Author Administrators Report Share Posted March 25, 2019 Late update, thought i would share a few shots, engine mount vacum pipe replaced and engine running smmother now theres no air leaks... Radiator in and all air burped 😁👍 5 Link to comment Share on other sites More sharing options...
SteviesV6 Posted March 20, 2022 Report Share Posted March 20, 2022 Can you point me in the direction of the cooler please and how to fit. I see there is 2 pipes coming off it Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 20, 2022 Author Administrators Report Share Posted March 20, 2022 3 minutes ago, SteviesV6 said: Can you point me in the direction of the cooler please and how to fit. I see there is 2 pipes coming off it Unless you are prepared to replace the radiator and possibly the A.C condenser I wouldn't suggest fitting a supplementary cooler as most of the kits involve attaching them to the radiator and your radiator and condenser a 20+-year-old will very likely spring a leak if disturbed? 1 Link to comment Share on other sites More sharing options...
SteviesV6 Posted March 22, 2022 Report Share Posted March 22, 2022 On 3/20/2022 at 7:52 PM, hughezee said: Unless you are prepared to replace the radiator and possibly the A.C condenser I wouldn't suggest fitting a supplementary cooler as most of the kits involve attaching them to the radiator and your radiator and condenser a 20+-year-old will very likely spring a leak if disturbed? Ah that maybe something I'd have to look into replacing or at least have to hand. Regarding the atf-u fluid. Is it bad for the carplan stuff to be mixed with what will be left over in the gearbox when I change or it is bad for it to be mixed with the amsoil good stuff? Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 22, 2022 Author Administrators Report Share Posted March 22, 2022 10 hours ago, SteviesV6 said: Regarding the atf-u fluid. Is it bad for the carplan stuff to be mixed with what will be left over in the gearbox when I change or it is bad for it to be mixed with the amsoil good stuff? FYI: old fluid won't mix with new fluid easily, but all new fluids will mix, I cannot imagine any problems mixing ATF-U with Amsoil... Link to comment Share on other sites More sharing options...
