Administrators hughezee Posted September 14, 2015 Author Administrators Report Share Posted September 14, 2015 Result least you know it can all be replaced if its ever needed in the future 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted November 7, 2016 Moderators Report Share Posted November 7, 2016 A little cheat i've often used in the past in this situation is to use an aftermarket silencer that will slide over the existing pipework, cut the old broken one out then slot the ends of the new one and clamp it in. If replacing a resonator this usually just results in a slightly deeper note but if replacing a silencer can make it noisier. Either way it's legal although not original. That said it's usually in the region of £20-40 for an aftermarket box to fit in place of one that has broken this way. Best result i had ever using this method was a £23 tractor silencer that had a baffle disc tack-wlded into the middle of it to create extra back pressure. I knocked this baffle out and fitted the silencer in place of the middle box on my Sterling, which had broken in various places and rotted on the pipework close to the silencer body. Not only did it make it quieter than the original but gave it a deeper tone and improved performance and economy. It lasted 6 years as well so wasn't a bad investment! 3 Link to comment Share on other sites More sharing options...
welland99 Posted September 19, 2018 Report Share Posted September 19, 2018 Well, happy to report thaf thd exgausf repaud from 3 years ago is still holding, but now the rear silencer is about to detach itself. Anyway, just wondering if anyone has any surplus useable exhaust components for a cg4 (2.0l). Is the cat the same on a 2.0 and a 3.0 litre? Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 20, 2018 Author Administrators Report Share Posted September 20, 2018 11 hours ago, welland99 said: Is the cat the same on a 2.0 and a 3.0 litre? The CAT is shorter on the 2.0, you can use parts from the UK saloon hatch models with some manufacturers needing minor adjustments. 3 Link to comment Share on other sites More sharing options...
