Zelman Posted April 9, 2023 Report Share Posted April 9, 2023 Does anyone know where I can purchase an interior ( map ) light bulb for a Honda Elysion. I can't see it anywhere on line. It's a fitting with with cables attached to a bank of 8 LED lights. I am wondering if it's worth the effort and I should just fit a simple bulb into the holder Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 10, 2023 Moderators Report Share Posted April 10, 2023 Can you post a pic of the current lamp? I think i know the thing you mean but want to be sure before i suggest a source Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 10, 2023 Moderators Report Share Posted April 10, 2023 13 hours ago, Zelman said: Does anyone know where I can purchase an interior ( map ) light bulb for a Honda Elysion. I can't see it anywhere on line. It's a fitting with with cables attached to a bank of 8 LED lights. I am wondering if it's worth the effort and I should just fit a simple bulb into the holder Is it a Honda fitment?? Didn't know they had any map light option....or is it a generic map light wired in perhaps ? Need pic as Laird_Scooby suggests. 1 Link to comment Share on other sites More sharing options...
Zelman Posted April 10, 2023 Author Report Share Posted April 10, 2023 I presume it's a Honda fitting. All the interior lights are LED's It's not specifically a map light it's just the usual interior light over the dash I have taken a picture but don't know how to insert it here! It appears I can only enter images from a URL source 1 Link to comment Share on other sites More sharing options...
st123 Posted April 10, 2023 Report Share Posted April 10, 2023 These are the ones i bought for my Elysion, https://www.autobulbsdirect.co.uk/501-abd-prime-4-led-12v-w5w-interior-wedge-bulb-pair.html 1 Link to comment Share on other sites More sharing options...
Zelman Posted April 10, 2023 Author Report Share Posted April 10, 2023 No, mine are like a fuse type bulb about 30mm long with 4 cables about 35mm long attached to a rectangular plate around 15 x45mm holding 8 LED bulbs. I can't find anything like it on line! 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 10, 2023 Moderators Report Share Posted April 10, 2023 19 minutes ago, Zelman said: No, mine are like a fuse type bulb about 30mm long with 4 cables about 35mm long attached to a rectangular plate around 15 x45mm holding 8 LED bulbs. I can't find anything like it on line! You mean something like this : https://www.ebay.co.uk/itm/314187380767 First, try turning the fitting round that goes into the original bulbholder - LEDs are polarity conscious so there's every chance someone has disconnected it and not put it back correctly. 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 10, 2023 Moderators Report Share Posted April 10, 2023 4 hours ago, Zelman said: I presume it's a Honda fitting. All the interior lights are LED's It's not specifically a map light it's just the usual interior light over the dash I have taken a picture but don't know how to insert it here! It appears I can only enter images from a URL source Oh, I see, the wires bits etc is inside the overhead lights ... not a separate map light...it was the wires bit confusing me !!! If you have the "fuse" type they are called "festoon" or "torpedo" bulbs / lamps. Like this https://www.ebay.co.uk/itm/284077381820 Search either term will get you a load of choices but watch the size, not just the length but the other dimensions. 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 10, 2023 Moderators Report Share Posted April 10, 2023 Them's the kiddies! The wire bit is only a convenient means offitting a larger LED panel that would fit in the "footprint" of a normal Festooon bulb. Often the "adaptor" is a spring loaded pair of Festoon contacts to accommodate a variety of lengths, think i have one somewhere and the LED panel too. 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 10, 2023 Moderators Report Share Posted April 10, 2023 2 hours ago, Laird_Scooby said: Them's the kiddies! The wire bit is only a convenient means offitting a larger LED panel that would fit in the "footprint" of a normal Festooon bulb. Often the "adaptor" is a spring loaded pair of Festoon contacts to accommodate a variety of lengths, think i have one somewhere and the LED panel too. It was the wire bit that confused me , easily done I know ,,,kept thinking about the map lights we used to have in the old "rally" cars ...poking out on a stalk !!! 🤣🤣🤣🤣🤣🤣 Got it now you explained the reason for them but never used that type ....except I just remembered I have two in the Elysion door lights as they project an "H" logo onto the floor too 😛😛😛😛😛 1 Link to comment Share on other sites More sharing options...
Zelman Posted April 11, 2023 Author Report Share Posted April 11, 2023 Thanks everyone for your assistance. I took your advice and cleaned it all up and it is now working ( albeit without 2 of the LED's ). The mystery still remains but at least the light is working now 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 11, 2023 Moderators Report Share Posted April 11, 2023 Definitely sounds like an aftermarket jobby. If (as i believe they were originally) it's a T10 fitting, these work well : https://www.ebay.co.uk/itm/334567810243?var=543657059804 You need to nick your wifes emery board (sandpaper on a lolly stick thing) and file off the sharp corners where the bulb enters the holder but they give a good light. Before ^^^^^ on standard filament bulbs. With those T10 LEDs in place of the original bulbs. Link to comment Share on other sites More sharing options...
