Wolf02 Posted August 18, 2022 Report Share Posted August 18, 2022 Hi, Next question, I have the tv built into the roof in the rear, it comes on and shows static as there is no signal coming in (Obv). I would like to use the video input sockets in the rear of the car as the source but I am unable to switch inputs as there is no remote with the car. Any suggestions ? Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted August 19, 2022 Moderators Report Share Posted August 19, 2022 Can't help with this as mine didn't have the screen but the outputs are still there in the centre console...maybe another owner can help...I have seen issues describing this but it was down to the failed dashboard sat nav radio screen up front...also its possible the output is not in a UK format.... radio 2 is about the only station you get from the standard Honda unit along with the "you are in the sea of Japan " sat nav problem 🤣 1 Link to comment Share on other sites More sharing options...
Wolf02 Posted August 19, 2022 Author Report Share Posted August 19, 2022 Lol. Thanks. I hope that it’s not controlled from the front screen (but suspect it is) as that has failed on mine. Have an android unit coming with a wiring harness so will see what I can do with it when that’s fitted. 1 1 Link to comment Share on other sites More sharing options...
