Administrators hughezee Posted December 31, 2021 Administrators Report Share Posted December 31, 2021 Houston we have a leak ๐ฎ I found a crack in the roof seam sealent.๐ค Cleaned the gutter and sealed it up last night, seems to have worked.๐ค 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted January 6, 2022 Author Administrators Report Share Posted January 6, 2022 FAIL water still getting in... ๐ง 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted January 7, 2022 Moderators Report Share Posted January 7, 2022 Could it be coming in from the external air intake via the heater matrix ? Had this on a couple of vans when leaves blocked drain holes and allowed water to come over the tops of the intakes in the bulkhead cavity....just a thought. Presumably there is no visible evidence of it coming in higher up , windscreen and the like , so underneath dash ??? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted January 7, 2022 Author Administrators Report Share Posted January 7, 2022 2 hours ago, PTR200S said: Presumably there is no visible evidence of it coming in higher up I tracked it down, well up to the roof, found a split/crack in the roof seam and I thought got it, but after cleaning the area in solvents I didn't see anything coming in that area or around the windscreen I thought maybe I had disturbed enough to stop anything coming in, so sealed it up.๐ค Nevertheless, I had my suspicions hence why I didn't put all the trim back just in case and after a few days of wet weather it has come back, my guess is it coming in further along the roof gutter somewhere. I will investigate when the weather permits, in the meantime plenty of tissue and moisture trap to keep the car dry.ย ๐ 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted January 16, 2022 Moderators Report Share Posted January 16, 2022 Captain Tolleys? https://www.ebay.co.uk/itm/322512805440 That particular one is out of stock at the moment but usually comes back in stock fairly quickly. Been watching it for quite a while now, not used it yet myself but has come highly recommended by others. As Mrs Beeton says, first catch your rabbit or in your case, first find your leak! 2 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted January 16, 2022 Author Administrators Report Share Posted January 16, 2022 I have some of this stuff alreadyย ๐๐ I have an idea of the source will update soon. ๐ค 1 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 24, 2022 Author Administrators Report Share Posted March 24, 2022 Finally getting to grips with the leak ๐ฌ roof rails removed, lovely day for it at least๐ 3 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted March 24, 2022 Moderators Report Share Posted March 24, 2022 It's not an optional extra foot spa as previously thought then Stu? 1 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 24, 2022 Author Administrators Report Share Posted March 24, 2022 1 hour ago, Laird_Scooby said: It's not an optional extra foot spa as previously thought then Stu? No unfortunately not mate............. ๐ 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 24, 2022 Moderators Report Share Posted March 24, 2022 2 hours ago, hughezee said: Finally getting to grips with the leak ๐ฌ roof rails removed, lovely day for it at least๐ ย Will be interesting to see if you find anything, got this problem on one of the Jazz and it has been suggested the rails are the problem too.ย 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 24, 2022 Author Administrators Report Share Posted March 24, 2022 2 minutes ago, PTR200S said: Will be interesting to see if you find anything Since removing the rails the roof gutters have revealed a few areas where water could be getting in with cracks in the seam sealant. I have fixed this issue on loads of civics over the years and a couple of accords very recently. 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 24, 2022 Moderators Report Share Posted March 24, 2022 5 minutes ago, hughezee said: loads of civics I think a Jazz qualifies as a "kicked up the arse" Civic !! 1 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 24, 2022 Author Administrators Report Share Posted March 24, 2022 29 minutes ago, PTR200S said: I think a Jazz qualifies as a "kicked up the arse" Civic !! Yup @Retro Rich had the same issue on his Jazz and sorted it ๐ 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 11, 2022 Author Administrators Report Share Posted April 11, 2022 Water leak fixed ๐ basically both roof gutters in the seams where the body meets the roof had visible cracks in the rear parts. This is aย common thing on all Hondas but since the roof rails made it tricky to track and the area I noticed water coming in led me in a different direction for a little while. Not forgetting the weather working against me all the way which is to be expected ๐ nonetheless the car is finally all put back together now. ๐๐ 1 1 Link to comment Share on other sites More sharing options...
