Max Posted March 15, 2021 Report Share Posted March 15, 2021 My elysion radio and nav sometimes does not switch on...especially when its hot and or I have run the engine..what could be the cause of that? If the engine is cold and or its cold outside, it always switches on. 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted March 15, 2021 Moderators Report Share Posted March 15, 2021 Sounds supsiciouly like dry joints in the radio and/or it's control unit. Could be other things that cause it though, also worth checking the earth points near the radio and other things for corrosion - does the radio alter its behaviour if you have other things switched on? 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 15, 2021 Moderators Report Share Posted March 15, 2021 It will be the usual dry joint problem, as Laird_Scooby says, these Elysion units are prone to dying like that 🙄 2 Link to comment Share on other sites More sharing options...
