Honda Elysion 3.0 Starter Motor
st123
  • Moderators
Quite a lot of owners have reported starters that have failed but usually on the 2.4 motors.
Have you got the starter out ?
Bench tested to be sure it is the starter ?
Bit of sideways thinking....is the gearbox lever in park ? ?...if so try wiggling it out of park and back in..
  • Like 2
Link to comment
  • Moderators
The part number on a 2004 V6 is 31200-RKB-004. (Trifoliate)
It shows as a 2006 Odyssey, 5speed or a 3 litre Accord (J30A4) too but as a Mitsuba.
One in Australia ! does yours look like this ?
https://www.ebay.co.uk/itm/Starter-Motor-for-Honda-Accord-Odyssey-V6-eng-J30A1-J30A4-Petrol-3-0L-3-5L-98-07-/123052357748
If you establish its the starter , not another fault like an inhibitor,  then a local alternator/starter motor is a good place to go for diagnostic and repair.
  • Like 2
Link to comment
  • Moderators
34 minutes ago, st123 said:
not got the starter out yet, tried the wiggle test with park nothing happened, have to get it recovered first lucky it is only 2 miles down the road, also is it easy to get to on the ely where is it?
Yep, easy access, discon battery and take out, take out lower battery platform, starter is to the left of the lower battery platform at front side of the engine....forward of the auto trans filter housing.
Might want to unclip the box that you move to get to dipstick for the transmission dipstick..bit more clearance above the motor.
Just discovered that the Mitsuba SM442-42 is also used/suitable replacement....if it turns out to be the starter failure then using the Honda numbers and this Mitsuba number you should be able to get a replacement unit from an automotive factors.
Has the starter been playing up before this?
  • Thanks 1
Link to comment
  • Moderators
went down the 2 miles down the rd to the supermarket
should have gone on the bicycle !!! (local council option!)
Let us know how you get on, sorry can't really help much further at this stage.
  • Like 2
Link to comment
  • Moderators
Slight variation on what Pete suggested, turn the key to the start position and hold it there then try moving the selector lever sideways left and right in the P position. If the Ely has the "Park lock" feature so the key can only be removed in P this may work, the fact there are two separate mechansims fitted on the P sector of the quadrant means they sometimes interfere with each other.
If this works, you have a work-around until such time as you can find the adjustment data to compensate for the wear in the mechanism(s) without the expense of a new starter motor.
Link to comment
  • Moderators
15 minutes ago, st123 said:
when it goes into park the doors unlock on mine so i know park is working
You only know that part of the switch is working. I don't know the exact system they've used on the Ely but if it has park-lock it means you can't remove the ignition key from the ignition switch unless it is in P, likewise you can't move out of P unless the key is in.
17 minutes ago, st123 said:
just had this from cox honda
 We can get hold of a genuine Honda one for £852.40 or a remanufactured Denso one for £396.40
They're having a laugh aren't they? You definitely need to be sure the starter is at fault before shelling out that much! Have you fed the solenoid energise terminal direct from the abttery?
  • Like 2
Link to comment
 from amayama MOTOR ASSY., STARTER (SM-44242-4G)
Genuine Honda (31200RKB004)
31200-RKB-004
Weight 3.47 kgs
Catalog MOTOR ASSY., STARTER (SM-44242-4G)
From
Price, GBP 540.71
Shipping cost to 58.00
United Kingdom
Delivered to you by
Availability
Japan540.7158.1802 - 05 Sep>1
This part may fit to
 For reference only. We're not guarantee 100% compatibility.
Brand
Honda
Model
Accord
Elysion
Inspire
Odyssey
Chassis
DBA-RR3
DBA-RR4
DBA-UC1
Engine
J30A4
K20A7
K20A8
K24A4
K24A8
J30A
J35A6
  • Like 2
Link to comment
  • Moderators
Amayama, 442 42 is mitsuba so should be good but as said Denso will be just fine.
Be interesting to see if the old one is an original honda unit and is it the solenoid or the actual starter windings that have failed....
Is the 500 quid warranty including labour ?
Worth exploring a repair at an auto repair shop
Link to comment
  • Moderators
11 hours ago, st123 said:
yes what am i going to do with the £40 per week saving !!
I am using fuel at an average rate of 24mpg, all short trip, round town stuff...really kills the mpg 😭
Save the £40 per week up, for your insurance ! 🙃......
Link to comment
