Administrators hughezee Posted April 18, 2020 Administrators Report Share Posted April 18, 2020 As a follow up to past discussions regarding brake fluid, I have illustrated the most common fluids used by myself or recommended by other members. So if you are looking for a standard fluid to TOP-UP you can use any standard DOT 4, but try to avoid using large amounts of generic fluid i.e flushing the system after maintenance or repairs on the braking system (you have been warned). Owners looking for great protection & responsive pedal or a one-stop solution I would highly recommend Comma DOT 4 ESP fluid. ๐ ย ย PLEASE NOTE: the information within this topic has been kindly contributed by one of our experienced members and has been extensively researched and found to be correct by independent testing or external resources. Regards SITE DEVELOPMENT. 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 18, 2020 Moderators Report Share Posted April 18, 2020 ๐๐ 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 18, 2020 Author Administrators Report Share Posted April 18, 2020 ESP version for the win Pete ๐ 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 18, 2020 Moderators Report Share Posted April 18, 2020 12 minutes ago, hughezee said: ESP version for the win Pete ๐ Mine has beenย in stock forย , ahem, a while !! 2 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 18, 2020 Author Administrators Report Share Posted April 18, 2020 2 minutes ago, PTR200S said: Mine has beenย in stock forย , ahem, a while !! Okay, I will let you off then ๐ not a huge fan of Comma stuff in general but the DOT 4 ESP is great. I purchased the standard DOT 4 in error and my coupe brake pedal travel increased switched back to the ESP and firmed up instantly to what was used too ๐ Viagra 4 Brakes ๐คฃ 1 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 18, 2020 Moderators Report Share Posted April 18, 2020 Interesting, mine might well be in stock a lot longer then !! haven't used it on the Coupe yet but did use it in the Tourer, x 2 actually and the pedal is fine...interesting though, the 04 plate Jazz has a long pedal, compared with the 06 plater, and that has this standard stuff in it 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 18, 2020 Author Administrators Report Share Posted April 18, 2020 3 minutes ago, PTR200S said: Interesting, mine might well be in stock a lot longer then I had already established the differences on lots of cars prior to my error with the coupe and thought it would be fine, but it wasn't, my own stupid fault ๐คจ 3 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 20, 2020 Moderators Report Share Posted April 20, 2020 On 4/18/2020 at 5:32 PM, hughezee said: I had already established the differences on lots of cars prior to my error with the coupe and thought it would be fine, but it wasn't, my own stupid fault ๐คจ That's called going above and beyond to really prove the point Stu! 2 Link to comment Share on other sites More sharing options...
