Founding Member Mazda Man Posted December 14, 2019 Founding Member Report Share Posted December 14, 2019 Good News! Lennie Legend now sounds like he should instead of a combine harvester, on a gravel road. Popped over to Stu’s earlier and he got to work on the bearing. I must say Cox Autoparts were great, the price of the bearing was reasonable (£117), it was a genuine Honda part and even better, it arrived a week quicker than expected. Right, back to the action shots... Here’s the bad bearing in situ just after removing the wheel: Followed by removing the monster calliper: Close up of the offending noise making bearing: Bearing removed, notice how dirty and contaminated it is, this was obviously cleaned thoroughly : Close up of old bearing: Brand spanking new sparkling bearing just out the box: And finally, new bearing fitted to Lennie: I’m happy to report that Lennie is now operating in stealth mode again and I can now hear the sat nav over the noise which was getting worse, despite driving and braking like a nun for the past few weeks. All is now calm, MOT due January and he should pass. Stu reckoned it had a few more weeks and it would have finally failed. The comparison - when you turn the new bearing in your hand to the old one - was really noticeable, the new one was tight and turned smoothly, the old one you could actually feel the grating and it wasn’t smooth either. As soon as Stu felt it he said “that’s toast”. Happy Days, I am somewhat relieved to say the least. Thanks again to Stu as always for spending a cold few hours fitting the new bearing! It was cold...I didn’t see my testicles until about 4pm! 😆. Be interesting to see the state of the innards of the old bearing too, I think they were literally ground to paste! 5 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 14, 2019 Administrators Report Share Posted December 14, 2019 Great to see you today mate and just glad it is sorted now, for those finicky amongst us 😋 rest assured the grease that was forced out of the old bearing and all grime was cleaned and rust & oxidisation sanded with 800 grit paper then mating surfaces were cleaned with lashings of brake cleaner for good measure and then a light film of grease applied to the area to aid fitting and help prevent future moisture ingress, also new 36mm on order as I only had 32mm 34mm spare.😑 4 1 1 Link to comment Share on other sites More sharing options...
Founding Member Brett Posted December 14, 2019 Founding Member Report Share Posted December 14, 2019 Glad your sorted Geoff and Lennie sounds how she should 5 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted December 15, 2019 Moderators Report Share Posted December 15, 2019 That's an easier wheel bearing change than mine was Geoff! Glad it's all sorted for you and you can now hear yourself think again! 4 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 15, 2019 Administrators Report Share Posted December 15, 2019 12 hours ago, Laird_Scooby said: That's an easier wheel bearing change than mine was Geoff! Yeah virtually the same setup on the RA1-RA5 Shuttle & Oydsssey's, although RA6 Odyssey and the 2.0 & 3.0 coupes not so easy 🤐 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted December 15, 2019 Moderators Report Share Posted December 15, 2019 9 minutes ago, hughezee said: RA6 Odyssey and the 2.0 & 3.0 coupes not so easy I take it they're similar to mine then, the whole knuckle has to come off and then the bearing is pressed out? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted December 15, 2019 Administrators Report Share Posted December 15, 2019 4 minutes ago, Laird_Scooby said: I take it they're similar to mine then, the whole knuckle has to come off and then the bearing is pressed out? Yup 😑 1 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted December 15, 2019 Moderators Report Share Posted December 15, 2019 Makes it a pain in various parts of the anatomy - in the end i had to find somewhere local with a press to get the bearing out on mine.. Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted December 21, 2019 Author Founding Member Report Share Posted December 21, 2019 Happy to report that all is well with Lennie’s new bearing, nice now being able to hear the sat nav, radio etc. Happy Days. 2 1 Link to comment Share on other sites More sharing options...
