Moderators PTR200S Posted April 5, 2020 Moderators Report Share Posted April 5, 2020 32 minutes ago, Laird_Scooby said: Yeah, i forgot to mention you need a cloth/rag to remove it when the engine is hot. Does get quite warm but doesn't drop lumps of plastic into the rocker cover like i saw one plastic OE cap do when it disintegrated! 😮 Mine's been on for at least 8 years, no problems at all. Nice cap, Dave !!! Bit concerned about the cable that appears to be cut above cap though !!! 😁 2 1 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 5, 2020 Moderators Report Share Posted April 5, 2020 5 minutes ago, PTR200S said: Bit concerned about the cable that appears to be cut above cap though !!! 😁 Thanks Pete, the reason that wire (alternator battery sense) is cut is to fit an alternator boost diode : This was to increase the voltage output from the alternator to cope with those poxy silver-calcium batteries : As you can see! 2 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted April 5, 2020 Author Moderators Report Share Posted April 5, 2020 Ah, I recall, is 14.72 your new output ??? 3 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted April 5, 2020 Moderators Report Share Posted April 5, 2020 It varies between 15.1 - 14.7V when charging Pete, once charged it doesn't try and push any more current in and keeps the voltage (usually) between 13-14V. Sadly the previous battery died from lack of use earlier this year so had to renew it again. Now i've started off with the correct charging voltage, this one seems to be playing the game as it should. 3 Link to comment Share on other sites More sharing options...
