st123 Posted October 25, 2019 Report Share Posted October 25, 2019 The Elysion Power Steering Pump Rattling Noise Right on top is sounds like a bearing gone, do i have to get a complete new one or can some parts be changed on it? 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted October 25, 2019 Moderators Report Share Posted October 25, 2019 Are you sure its a bearing ? these pumps are prone to seal leakage and suck air into the system creating a noise.... Can you see if any air is being fed back into the PS reservoir? You can buy all the seals to rebuild the pump..... 😜 at a price ! If you are lucky it might just be the feed/supply pipe seals causing the problem....do you have any leakage anywhere? sometimes the seals on the back of the pump go but you will see some seepage. If you still think its the bearing take the belt off and turn the pump by hand, you will feel any problem immediately if it is making noise. Edit: another thought, have you changed the PS fluid recently? did you bleed it thoroughly? 4 Link to comment Share on other sites More sharing options...
st123 Posted October 25, 2019 Author Report Share Posted October 25, 2019 will start with a fluid change and check for leaks when it`s not pissing down 4 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted October 25, 2019 Moderators Report Share Posted October 25, 2019 Raining here too, and then some !! 🐳 3 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted October 26, 2019 Moderators Report Share Posted October 26, 2019 Like Pete says, old (or low) fluid in the pump can cause cavitation which can sound like a rattle. Worth checking the level to start with, topping up if needed. Then get a big syringe and empty the reservoir with it. Discharge the syringe into a white plastic container (Pot Noodle pots are good for this) so you can see the dirt if there is any. Top up with new fluid, start the engine and turn the steering from lock to lock several times slowly to bleed the system. Recheck the level then repeat this weekly untl the fluid is clean. This will hopefully sort you out - or at least the PAS pump! 2 Link to comment Share on other sites More sharing options...
st123 Posted November 6, 2019 Author Report Share Posted November 6, 2019 Changed fluid looked like it never been changed, checked all hoses no leaks pump now back to normal👍 4 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted November 6, 2019 Moderators Report Share Posted November 6, 2019 Good to hear it's sorted, don't forget to do another part change as described above in a week or so followed by weekly until the fluid stays clean. 3 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted November 6, 2019 Moderators Report Share Posted November 6, 2019 Excellent news, nothing like a fluid bleeding change !!! 3 Link to comment Share on other sites More sharing options...
BoMar Posted November 6, 2019 Report Share Posted November 6, 2019 I've changed all the seals from PS pump because of a loud grinding, whining noise and flushed the system and all great again. By the way Mike Raven has helped me posting the car for sale but for some reason I can't reply to topic so if anybody interested please reply here or to me directly. Or if anybody knows how to reply on that topic please let me know. Thanks 3 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted November 7, 2019 Administrators Report Share Posted November 7, 2019 22 hours ago, BoMar said: if anybody knows how to reply on that topic please let me know. The classifieds are reserved for site subscribers we had few people join just to sell a motor, feel free to message me directly with any details you would like to add fella... 2 Link to comment Share on other sites More sharing options...
BoMar Posted November 10, 2019 Report Share Posted November 10, 2019 On 11/7/2019 at 7:22 PM, hughezee said: The classifieds are reserved for site subscribers we had few people join just to sell a motor, feel free to message me directly with any details you would like to add fella... Fair enough At least I know what the issue was 😉 Thanks 2 Link to comment Share on other sites More sharing options...
