Mangoman Posted November 25, 2016 Report Share Posted November 25, 2016 How many lights should there be for the Rear Fogs, just one on the right or both? (Disappointing that in the States the light up as secondary brake lights.... ) See here in the beginning of this clip: Link to comment Share on other sites More sharing options...
Administrators hughezee Posted November 25, 2016 Administrators Report Share Posted November 25, 2016 We only have one fog, not all is lost as a few people have done the modification, just remember to mirror the active light in terms of ventilation as you will warp the light housing like one member discovered Just a couple of shots of the last modification I did for somebody 3 Link to comment Share on other sites More sharing options...
Mangoman Posted November 25, 2016 Author Report Share Posted November 25, 2016 Thanks.... Where did you get the Light Fitting from? Link to comment Share on other sites More sharing options...
Administrators hughezee Posted November 25, 2016 Administrators Report Share Posted November 25, 2016 I have lots of spares 2 Link to comment Share on other sites More sharing options...
Mangoman Posted November 26, 2016 Author Report Share Posted November 26, 2016 On 11/25/2016 at 10:29 PM, hughezee said: I have lots of spares That sounds handy... Thanks. Link to comment Share on other sites More sharing options...
Harry93 Posted March 30 Report Share Posted March 30 Can anyone shed a bit more info on this? When adding the second rear fog light, which cable/wiring are you meant to tap into? I'm guessing it's obviously the factory rear fog on the driver side, but is there any way to avoid feeding wire across the light bar than simply tapping into the factory wiring harness somewhere on the passenger side? 1 Link to comment Share on other sites More sharing options...
Harry93 Posted April 7 Report Share Posted April 7 Wasn't 100% sure on the best way to wire the passenger side, but after no reply, I just thought I would tackle it myself. So obviously the passenger side doesn't have a bulb socket holder, so I had to source and waste money on a corner light just for the socket wiring. I extended the factory wiring with some 5 amp cables, enough to reach the driver side rear. I wanted to keep the wiring colour coded but had to make do with what I had at the time. Factory black/white cable being negative, and the green/yellow being earth. As mentioned way above on the thread, drill through the tail light using a big enough drill bit or a hole saw attachment (a circle outline is engraved, where the bulb sits inside, aswell as ventilation holes around the black bulb housing). Any debris from drilling, use an air line, compressed air or a vacuum to get them out. Feed the wire inside the boot lid reaching the other side. With the extended wiring reaching the driver side, I used some cable connectors to tap into the factory wiring harness for the driver side rear fog. As shown above, factory black wire is the negative -, and the red/blue being the positive +. Finished result. Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 13 Administrators Report Share Posted April 13 Sorry for missing this one I strongly recommend you disconnect the extra bulb and wire them both separately on a relay with a new power feed as everyone that's attempted a DIY overloaded the multiplexrer unit or damaged the fuse box. 1 Link to comment Share on other sites More sharing options...
Harry93 Posted April 13 Report Share Posted April 13 1 hour ago, hughezee said: Sorry for missing this one I strongly recommend you disconnect the extra bulb and wire them both separately on a relay with a new power feed as everyone that's attempted a DIY overloaded the multiplexrer unit or damaged the fuse box. I was in the unknown on this. Not easy finding OEM wiring for the rear fogs. I know it's a bit risky powering it off the original side. Am I right in understanding it's best to wire both of them with 2 relays, one for both sides? Also when you mention the power feed, is that by getting power direct from the fuse box or a different harness within the boot lid? 1 Link to comment Share on other sites More sharing options...
