Founding Member PaulS Posted August 28, 2017 Founding Member Report Share Posted August 28, 2017 Been out for a run today and seem to have a grumbling wheel bearing. Not sure where as yet WIth front O/S damage repair and a recent rear O/S brake burn its not that surprising........ But looking around there seem to be some reasonably priced Optimal front bearings (£36 ish) but rear bearings seem to come as a replacement hub - is that correct? Are Optimal bearings OK? Or are there other recomendations? Or even recomendations for salvaging what I have in place already? 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted August 29, 2017 Administrators Report Share Posted August 29, 2017 18 hours ago, PaulS said: Are Optimal bearings OK? Hi Paul sorry to hear of your suspicions regarding the bearings, never tried optimal bearings on a Honda, I'm genuine OEM or blueprint man myself in this area anyway. Also, you are correct in thinking it's odd about the rear bearing, but it is normally offered as a complete hub assembly, makes it a dearer job though. 1 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted August 31, 2017 Founding Member Report Share Posted August 31, 2017 When my old coupe Bluey's bearing was shot the noise was more noticeable under load, ie when turning corners. 3 Link to comment Share on other sites More sharing options...
Graymalkin Posted September 7, 2017 Report Share Posted September 7, 2017 Ahhhhh this explains a lot. I think my front drivers side is going..... Ufffff 2 Link to comment Share on other sites More sharing options...
