Founding Member AhsyV6 Posted September 12, 2014 Founding Member Report Share Posted September 12, 2014 Any chance anyone knows how to change these bulbs? I have tried for soooooooo long but it actually looks as if they're sealed units. Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 12, 2014 Administrators Report Share Posted September 12, 2014 These are tricky m8 if your feeling up to it there are three screws holding it in the behind the bumper if memory serves leave the one that has a spring "Adjustment Screw" once screws are removed and then take the unit out. Then there are some screws on the rear or bottom of the housing that you have to remove as well just to get at the bulb (H3 bulbs I believe). Hope this helps Any follow up pic's would be appreciated Link to comment Share on other sites More sharing options...
Founding Member AhsyV6 Posted September 13, 2014 Author Founding Member Report Share Posted September 13, 2014 Thanks mate, I will give it a go again and take some pics. Thanks again Link to comment Share on other sites More sharing options...
Administrators hughezee Posted September 21, 2014 Administrators Report Share Posted September 21, 2014 I forgot to mention you will need to remove the bumper http://honda6.ipbhost.com/index.php?/topic/32-accord-coupe-front-bumper-removal-how-to/ Keep us posted Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 1, 2016 Administrators Report Share Posted March 1, 2016 Just to clarify any confusion for members these units are not permanently sealed, its been I while since I replaced fog light bulb on a coupe but I have removed and resealed a leaking or broken lenses more recently by removing the three front screws and a heat gun to melt the seal. I have replaced similar styles all differing slightly in bulb fitments this could be where the confusion came from. Nevertheless I knew they weren't sealed and pictured above are both 1999 -2000 versions which are identical and for the best access you still need to remove the bumper in my opinion and remove the whole assembly to avoid damaging the three (smaller) phillips head screws 1 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted March 1, 2016 Founding Member Report Share Posted March 1, 2016 Great post. 1 Link to comment Share on other sites More sharing options...
