A53Platty Posted September 3 Report Share Posted September 3 The Garage have just called & told me almost all the parts I supplied are incorrect. I used this post as a guide: https://honda6.ipbhost.com/topic/6741-honda-elysion-discs-and-pads/?do=findComment&comment=44997 and cross referenced myself on Amayama, coming up with the same numbers & leaving my parts supplier to source aftermarket equivalents. The only thing that's right is the rear pads, which are the only things I thought might be wrong as there were 2 types. I guess I got lucky with them at least, as the rear discs dont actually need changing... So the front & rear discs are too small for the hub flanges & the front pads are the wrong shape. And I didn't confirm the VIN number while I was at home at the weekend. 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted September 3 Moderators Report Share Posted September 3 Well I would say that is down to your parts supplier not doing the cross reference properly. If you have got the correct numbers from amayama.com or even Cox motorparts then they will be correct. I have a pair of s/hand front disks I can measure up for you, however Cox list them here.. https://www.coxmotorparts.co.uk/elysion-brake-pads-and-discs/genuine-honda-elysion-front-brake-discs/ Link to comment Share on other sites More sharing options...
st123 Posted September 4 Report Share Posted September 4 Just get them from cox honda, yes they are more expensive but you know you have the correct parts 1 Link to comment Share on other sites More sharing options...
