Moderators PTR200S Posted March 2, 2022 Moderators Report Share Posted March 2, 2022 Arghh, got water in the lenses of reversing light..presumably that means water everywhere in the tailpiece light fitting. Any tips for removing the panel without busting it ?? I am sure I have seen a thread somewhere..... 2 Link to comment Share on other sites More sharing options...
KingK0ng Posted March 3, 2022 Report Share Posted March 3, 2022 Hope it helps 1 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 3, 2022 Administrators Report Share Posted March 3, 2022 On 3/2/2022 at 3:40 PM, PTR200S said: Any tips for removing the panel without busting it ?? I am sure I have seen a thread somewhere..... I think this is what you are looking for Pete, however, if there's water inside the cluster it could be the lens separating from the backing or the 0-ring around the keyhole has failed? 2 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 3, 2022 Author Moderators Report Share Posted March 3, 2022 Thanks Kingkong, that looks easy enough !!! Bet everything is rusty !!! As I am off tomorrow so its on the list I think, after the 04 plate Jazz gets its new rear hub bearings and drop links fitted 😛 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 3, 2022 Author Moderators Report Share Posted March 3, 2022 35 minutes ago, hughezee said: I think this is what you are looking for Pete, however, if there's water inside the cluster it could be the lens separating from the backing or the 0-ring around the keyhole has failed? Thanks , knew I had seen it somewhere, I even commented on it in 2017,,,,long time ago, slept since !! At that time mine was OK, but not anymore 😭 Need to spray my nuts I think 🤪🤪🤪 don't want them dropping off !! 2 Link to comment Share on other sites More sharing options...
KingK0ng Posted March 3, 2022 Report Share Posted March 3, 2022 On 3/2/2022 at 4:40 PM, PTR200S said: Arghh, got water in the lenses of reversing light..presumably that means water everywhere in the tailpiece light fitting. Any tips for removing the panel without busting it ?? I am sure I have seen a thread somewhere..... My apologies i misread your message. Though you where asking how to remove the tailight. As for not busting it i think would be difficult to do so. The piece is quite sturdy. When i removed mine after removing the bolts i just gently push from inside on each threads to make it slightly pop-out then grab it and removed it. Should come off really easely. Thing you may notice ( or hopefuly not ) is the holes on the trunk panel where the tailights threads goes in may be rusty and even start decomposing, if so take the occasion while it's disassembled and treat it. 1 1 Link to comment Share on other sites More sharing options...
