ccupton Posted March 3, 2021 Report Share Posted March 3, 2021 Hello All, I have a J35a3 in my sand rail and i am looking to gain some horse power without doing to much to the engine. 1 Link to comment Share on other sites More sharing options...
Moderators PTR200S Posted March 4, 2021 Moderators Report Share Posted March 4, 2021 Welcome to H6nda, this may not be the right forum for you for modification details but someone here might be able to help or point you in the right direction. What have you done to the motor to start with? When you built the Sandrail did you just put the stock motor in ? Or mod the intakes ........and presumably you must have already modded the exhaust to fit the chassis rail configuration anyway? 2 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted March 4, 2021 Administrators Report Share Posted March 4, 2021 17 hours ago, ccupton said: i am looking to gain some horse power without doing to much to the engine. Apart from what member @PTR200S has mentioned, if your not looking to do much to the engine I can't imagine any real improvement you could achieve? Maybe fitting a nitrous injection kit would give you the most bang for your buck, when setup correctly? 2 Link to comment Share on other sites More sharing options...
ccupton Posted March 5, 2021 Author Report Share Posted March 5, 2021 On 3/3/2021 at 8:41 PM, PTR200S said: Welcome to H6nda, this may not be the right forum for you for modification details but someone here might be able to help or point you in the right direction. What have you done to the motor to start with? When you built the Sandrail did you just put the stock motor in ? Or mod the intakes ........and presumably you must have already modded the exhaust to fit the chassis rail configuration anyway? Stock motor with custom headers. That is it so far. Are there mods to the intake or tuning tricks i can do to help. 1 Link to comment Share on other sites More sharing options...
