Moderators PTR200S Posted May 30, 2020 Moderators Report Share Posted May 30, 2020 Just checked mine out against the "A " pillar. Measurement is a couple of mm out... Wider on the passenger side but marginal...that side has the fuse box on it and appears less rigid because of it. The fuse cover curves in slightly at the door jamb point too, making it seem wider. I think this could be a production tolerance issue in that after fitting at the factory it would classed acceptable. 1 Link to comment Share on other sites More sharing options...
KingK0ng Posted May 30, 2020 Author Report Share Posted May 30, 2020 29 minutes ago, PTR200S said: Just checked mine out against the "A " pillar. Measurement is a couple of mm out... Wider on the passenger side but marginal...that side has the fuse box on it and appears less rigid because of it. The fuse cover curves in slightly at the door jamb point too, making it seem wider. I think this could be a production tolerance issue in that after fitting at the factory it would classed acceptable. Thanks for your inputs Pete, appreciated. 1 Link to comment Share on other sites More sharing options...
