Administrators hughezee Posted April 18, 2020 Administrators Report Share Posted April 18, 2020 As a follow up to past discussions regarding Coolant/ Antifreeze and the problems associated with using Honda Type 2 Coolant p/n: 08CLAG026L0 when used in some vehicles, which results in annoying leaks, vapour leaks and really unpleasant persistent odours (also requires replacement every 2 years). Although these symptoms from using Type 2 coolant can be elevated with some water dilution to the 50/50 mix up to 65% water to 35% coolant mix, improving the heat exchange process. So I have illustrated one of the most common fluids used by myself or recommended by other members, so if you are looking for a standard fluid to TOP-UP you can use Honda Type 2 Coolant, but try avoid using large amounts i.e flushing the cooling system after maintenance or repairs on the cooling system (you have been warned). Owners looking for great protection or one stop solution or just a TOP-UP I would highly recommend Prestone Coolant Antifreeze. ๐ PLEASE NOTE: the information within this topic has been kindly contributed by one of our experienced members and has been extensively researched and found to be correct by independent testing or external resources. However' when replacing radiators and water pumps, some manufacturers insist on genuine coolant for warranty purposes, please adhere to this advice. Regards SITE DEVELOPMENT. 5 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted April 19, 2020 Founding Member Report Share Posted April 19, 2020 I keep a small bottle of this in my boot, Asda sells it and sometimes itโs on offer too.ย 4 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted April 19, 2020 Author Administrators Report Share Posted April 19, 2020 5 hours ago, Lennie Legend said: Asda sells it and sometimes itโs on offer too.ย ย Most supermarkets sell Prestone, surprised you don't carry Demon Cool Geoff ๐ 4 Link to comment Share on other sites More sharing options...
Founding Member Mazda Man Posted April 21, 2020 Founding Member Report Share Posted April 21, 2020 Ha ha, I only buy stuff that comes with the Honda Man Seal of Approval, you know that.ย ๐ 3 Link to comment Share on other sites More sharing options...
