Amjid Zeb Posted October 10, 2019 Report Share Posted October 10, 2019 Hi need a bit of help with a slight issue where does the sunroof drain pipe come out from as I assume they are blocked and is it possible to get a sunroof seal any help will be appreciated thanks 😊 1 Link to comment Share on other sites More sharing options...
Administrators hughezee Posted October 11, 2019 Administrators Report Share Posted October 11, 2019 The drains should exit on each corner of the car inner front wing and behind the rear bumper sides? You should be able to see where they exit more accurately removing some interior trim, pulling back the carpet from the footwells looking upwards or removing the boot side trims... 2 Link to comment Share on other sites More sharing options...
Moderators Laird_Scooby Posted October 14, 2019 Moderators Report Share Posted October 14, 2019 This is a very common problem on the Rover 800, the "sister" car to the Legend. If you remove the kick panels in the front and have a good look with the aid of a torch, you should find the sunroof drains. The look something like this but you won't be able to see the "teat" bit as that will be outside the car as it passes trhough the inner wing to the outside world : Pictured next to the valve (as Honda officially call it) is the best known fix i've found. It's a 14 x 10mm hosing reducer. Smooth off almost all of the ridges on the smaller end (leave a little of them to help with grip), smear some Araldite onto the small end and push it into the down-tube from the sunroof. Now push the thicker end into the valve and refit it to the inner wing. That gives an idea what i mean but push the thick end all the way in. Â The rear drains can be seen just down and left of centre in this pic : The black loop of wire (which happens to be the rear ABS sensor) makes a circle almost round the sunroof drain hose and valve - give these the same treatment as the fronts. https://www.ebay.co.uk/itm/5X-10mm-to-14mm-Straight-Reducing-Hose-Pipe-Tube-Connector-for-Air-Fuel-Water/333211213867 That's the wee beasties. As yours is the Legend, they might be in a slightly different place but not far off i wouldn't think. 2 1 Link to comment Share on other sites More sharing options...
